Long Pull fuel problem solved. - Ford Powerstroke Diesel Forum
Old 09-13-2010, 01:45 PM
Going on trips started to suck. Every place i go I get about 7.5-8 until I can get on an interstate. Pismo Beach, Southern Cali, etc. all good hills for a extended period of time.
Solved.
Some advice. I would not get a tank 60" wide, this was bad enough. The tabs on the side had to be bent up because of the bed of the truck. I would put a fuel filter in line of the before the fill tube of the truck. I already clogged the first one I put in. Must have been some crap left in the tank. Works great so far, an extra 60 gallons works great.
Old 09-13-2010, 02:05 PM
What brand? How'd you plumb it in to the system?
Old 09-13-2010, 02:37 PM
RDS from Northern Tool.
It is plumbed into the main fill neck hose.
Old 09-13-2010, 04:29 PM
Warheads on Foreheads
wow 90 gallons of fuel is $$$$$$
