| 6.4 Exterior Discussion Body and Accessories Talk |
Icon leveling kit questions
Would it be possible to run a 2.5" icon kit along with the 1" tei spacers for a total of 3.5" or is this a bad idea? This would be on an 08 4x4 crew cab.
Yes you can, you must get a adj track bar to recenter the axle after the lift. We are a Icon dealer if you need additional info-prices please PM me with your info and zip.
Thanks, Cary |
has anybody on the site done this?
Be doing mine this weekend if the rest of it shows up talked to icon directly said no problem with that setup and Cary also said no issues with it!! I think its safe!!!
Chris |
Yes you can do that combo, but why not just get the 4.5" kit?
if you would do this setup wouldnt you need drop brackets for your radius arms???
and if so why not go with the 4.5 but i think 3.5 would look real good if you dont need drop brackets.. wonder what size rear block would work im thinkin 4.5
No drops needed just a adjustable track bar to center the axle i spoke with icon they said that is all that is needed the caster cams are enough to still keep it in the safe range. I added the same 3.5" to the rear to keep the f250 stance and you can do this kit for around $1100 with less work than the 4.5" plus save $800 another 1" ain't worth that to me!
![]() Chris |
stroke4fun please post pics when u get done . i will prolly do the same to my 2011.are u goona run 35s as well?
stroke4fun im pretty sure if u go 2.5 4 inchblocks in the rear r pretty close to level so with 3.5 wouldnt u need 4.5 or 5 inch rear blocks....like i say im not a tech but im pretty sure 3.5 in rear will sag
