| 6.4 Exterior Discussion Body and Accessories Talk |
6" or 8" lift with 37s
CANT DECIDE BETWEEN 6" OR 8" LIFT. LOOKING TO DO 37"TIRES ON 20" AFTERMARKET WHEEL. DOES ANYBODY HAVE ANY PICS OR SUGGESTIONS. ALSO WOULD LIKE SUGGESTIONS ON LIFTS. I AM CURRENTLY 4"LIFT WITH 37s ON THE 20" FACTORY WHEEL. THEY RUB AT FULL TURN. THANKS
def go with the largest lift..... from my experiance (1bout 4 diff lift kit heights) you always want to go bigger....
Go with the 8". You'll want to go higher sooner or later and 8" is still reasonable. I have a 6" Pro Comp with 37's on factory wheels and they still rub at full lock. I'm sure they would still rub with an 8" on factory wheels. With the right offset on aftermarket wheels, they shouldn't rub with either height. As far as brands, my pro comp works great for a cheaper lift. If I were to do it all over again, I would go with the Rize with Bilstein shocks. Their radius arm drop kit wasn't much more than the pro comp.
ProComp 6" on 22's. Been a nice lift so far. Definetly upgrade on the shocks, I went with some bilstein's and it made a big diffrance.
6" lift, 37x15.5x20, 20" moto metal 951, had to cut out and move bottom back edge of wheel well back about 2". Perfect turning now even flexed out
Go actually find where the rubbing is occuring ... everyone keeps mentioning tire rub at full lock. This is likely rubbing on the leaf spring... for which a lift kit will not do anything for you. A rub on the wheel well is likely to occur somewhere between straight ahead and full lock because in the middle is where the edge of the tire will be closest to the wheel well (it pulls away again at full lock).
If you're getting rubbing on your leaf spring then you're going to need less offset on your wheels. All the lift in the world won't fix that rub if you have the wrong wheel offset. |
Mine rubbed at bout half lock |
Did you have the ES9000 on to begin with? Did the Bilsteins really make that big of difference? I have been contemplating on putting some Bilsteins on for a while. I just don't want to waste the money if they aren't going to make any difference.
I had the ES9000 on for 3 weeks before the bilsteins came in. For the diffrence in price i think it was worth. Over all the whole ride was way smoother. They sure made the rear end smoother. In the front it took away all the jaring on the really rough roads
