8inch lift to a 10inch lift - Ford Powerstroke Diesel Forum
Old 08-05-2010, 07:06 PM
I recently put an 8 in rough country lift on my 09 6.4 What is an easy and cheap way to raise it to a 10inch. Please any advice will help!!!
Old 08-05-2010, 07:23 PM
Heres a pic of the truck as of now
Old 08-05-2010, 07:57 PM
I personally would leave it at 8inches, but if you want more lift. I think you could just use larger blocks and longer shocks.
Old 08-06-2010, 03:10 PM
your truck looks fantastic, i vote leave it. what size tires and wheels ou on now?
Old 08-06-2010, 05:30 PM
i vote to leave it as is. you'll probably end up spending too much money for just that a little extra lift. its an awesome truck..
Old 08-06-2010, 05:37 PM
Feedback Score: 5 reviews
what are you using for lift in the rear?
Old 08-06-2010, 06:02 PM
Im running 37x13.50x22r Nitto Grapplers far whats in the back is just blocks!!
Old 08-06-2010, 06:13 PM
On the rear you could run a Traction Block setup. You can get whatever size you want. I just got mine in the other day. They are 10" blocks. Here is some info on them:
Fabricated Unitized Floating Traction Block - Precision Metal Fab
Old 08-07-2010, 07:03 AM
You can add an 2 inch spring spacer for the front and an add a leaf for the rear so you wont add more blocks.. But you are eventually going to need some kind of traction or ladder bars for the rearend to keep it in place... Pretty much what txfireman said above but a little cheaper...
Old 08-07-2010, 07:06 AM
My traction blocks are for sale, never been installed. They sell for $850 plus $150 for the optional 3/4" Zinc Plated UBolts.
$750 and they are yours
