| 6.4 Exterior Discussion Body and Accessories Talk |
HELP! ICON leveling kit issues
I ordered an icon leveling kit w/ shocks from truck toyz and know that im done installing everything i go to put the last shock on and its different than the other one. One shock has the piston on the bottom (mounts to the axle) and the other one has the piston at the top. They are both the same length but different? Is it supposed to be that way? Should i mount it up and go? Everywhere is closed today, need some advise.
I would mount it up if you need the truck see if it works ok then call trucktoyz when they get back in from the holiday i am sure they will swap it out for ya!
Chris |
what happened was they sent you 1 Edelbrock shocks body up style and 1 Bilstein body down style. Those are the 2 company's that make Icon shocks. That happened to me as i got 2 Bilsteins and had 2 Edelbrocks. And then they had to seed me 2 Edelbrocks to match. I like the Edelbrocks better as they are body up and have a clear coat on them. I would install it so you can drive and have them send you out the correct shock on Tuesday.
Ok, thanks guys
