| 6.4 Exterior Discussion Body and Accessories Talk |
Grille R+R
Got a new grill thanks to 4mm on the site! Can somebody tell me how this damn thing comes off and on? Looks like 7 push pins and a few bolts but who knows? Please help I do not want to screw anything up or break anything. I am a proud owner of an 08 king ranch F250 w a 6.4L. Thanks
be verrrrrrrrrrrrrrrrrrrrrry careful pushing those darned little rivets out, best to take needlenose pliers and squeeze from behind the grille and push out, be very careful once you get them all out then pull up be careful you dont break the clips
Glad to see you received it in good condition. Just remove those bolts and push the bottom of the grille upwards from one side to the other. It will start popping off, you can wedge some cardboard under the top side of the grille that pops off so it won't snap back into the slots. I never used pliers and didn't damage anything, but you can use them if you prefer.
It looks like seven plastic rivot bolts and maybe two lower bolts. U don't take the bolts off the hood right? Then once it's off I change the inserts n snap it back on? Is this headin the right direction or am I way off. I don't want to screw anything up. Thanks
