Rim Gurus need help!!! - Ford Powerstroke Diesel Forum
Old 06-26-2010, 04:45 PM
Send a message via AIM to Duffie112
what offset would i need on a set of 22" bmf novakaines with a leveling kit? i plan on running a nitto terra grappler or toyo open country a/t.. also what tire size should i run?? i want the tires to stick out a little bit not alot..any thoughts?? thanks guys
Old 06-26-2010, 04:49 PM
Feedback Score: 9 reviews
5" of backspace should be plenty, but it really depends on what size tire you are running, not rims.
Go with 4.5" of backspacing if you want them to really stick out
Old 06-26-2010, 04:57 PM
i was just reading that bmf 22x10.5 u need a minimum of a lift not a leveling kit? is this true??
Old 06-26-2010, 04:59 PM
I'm pretty sure that a lift wouldn't be necessary, pending what size tire you are getting. 35's would fit with ease.
Old 06-26-2010, 05:23 PM
now what does a 35'' tire convert to like ???/??/22 thanks man..
Old 06-26-2010, 05:32 PM
325/50/22 is one size, but I'm sure there are a LOT more sizes to choose from. Honestly, I would go with a 20" rim, it will save your money and the off-road look of your truck. Upgrading to 22" wheels and tires is like a 50% increase in cost compared to 20's.
Old 06-26-2010, 05:40 PM
if i went with the novakaine in 20's what width should i go with 9 or 10 being id like it stick out around an inch or so. and what tire would fit good with a 20? i didnt realize how much more it is to go from 20 to 22 lol damnn that crazy
Old 06-26-2010, 05:56 PM
10", and 35x12.50x20's would look perfect
