Pics of 22" incubus nemesis rims on 08 with a/t tire. - Ford Powerstroke Diesel Forum
Old 06-24-2010, 01:34 PM
Send a message via AIM to Duffie112
trying to see what incubus nemisis rims would look like on our trucks, if im leveling the truck what offset do i run with a 22" rim and what size tire can i fit? thanks in advance
Old 06-26-2010, 07:18 AM
well seeing that its a 22 the smallest tire you'll find(and look ok) is a 37,you should be able to run a 37 with a leveling kit,however you will probably rub a little unless you do a little trimming,for the offset,i would try to stay on the neg, side,it all depends on the width of the rim,good luck with it
