| 6.4 Exterior Discussion Body and Accessories Talk |
Rear lift height?
I have decided to install the 6" bds 4 link kit and i am getting some blocks/bars from pmf what size rear blocks will let the rear sit a little higher than the from 7" ? that's what i am thinking just what to be sure before i do the order.
Chris |
You have a 2.5" stock block so you would need about a 7" your right....
Is it even 2.5" i thought they were just under 2" on the 250's ?
Chris |
I would put the lift on with the blocks that come with it first to make sure because on the truck I just sold I had a 4'' lift and needed 6'' blocks to make it sit level.
The kit comes with 5" rear blocks so i know they will be low Bds states that in the details for the prerunner look!
Chris |
Mine were like 2.25-2.5 I forget bu over 2" I am pretty positive.
You will need a 6" t o sit level, and 7" for a rake |
I always go 2" inches higher in the rear then in the front 6" in front I say 8" in back. I.m running 8" in the front and 10" in the back and I like the rear to sit a little higher.
How much taller in the rear are you with the 10" blocks have you measured the wells?
Chris |
I don't have a 10" block but I'm running 6" lift leaf spring and a 4" block. I think of the top of my head its 1.5 or 1.75 higher measuring the top of the tire to the fender from the front to the back.
Got ya all i would like is around 1"+ in the rear that should be fine I hate trying to figure this stuff out!
