Wheel ? 9" or 10" Wide - Ford Powerstroke Diesel Forum
Old 04-28-2010, 04:49 PM
I am going to order a set of Novakane's but don't know if i should go 20x9 or 20x10. Right now i got 35x12.5x20 toyo mt's and might do a bigger lift and 37x13.5x20 later. will a 9" wheel work with a 13.5" tire on it or should i do a 10"? I like the 9" for the 0 off set or 5" BS. and if a 9" wheel will work will it look funny with a 4.5" lift on 37x13.5? Thanks and if you pics of something close post them up.
Old 04-28-2010, 04:53 PM
I think 9" is the minimum requirement for 13.5's. Get the 10" just in case.
Btw why are you selling those wheels the truck looks awesome?
Old 04-28-2010, 04:58 PM
Thanks,
I like the way the BMF Novakanes look and i see a lot of my style of wheel around where i live.
Old 04-28-2010, 05:00 PM
Originally Posted by wired1 View Post
Thanks,
That aint a bad reason and I agree the Novakanes look good.
Old 04-28-2010, 05:18 PM
I would think it depends more on how much tire you want to stick out. I went with the 20x10 and -19mm offset and a 325/60 Terra Grappler which is 35.35x12.9 wide, you can see the extruded portion of tire:
I rubbed the fender well slightly with my 4.5" lift, I imagine 37s would clear or be the same with your 6" lift.
Old 04-28-2010, 06:01 PM
Go 10" wide IMO.
Old 04-28-2010, 06:10 PM
I would get the 10" wide. Just in case you want to get a bigger tire later.
Old 04-28-2010, 07:48 PM
I would go with the 10's for a 13.50 tire.
I have 18x10's with 35x13.50's and they go together very well
Old 04-28-2010, 07:53 PM
Get the ten inch wide wheel. I couldn't afford to get the ten inch wheel at the time I bought my new tires so I opted out of even getting 9" wide wheels
With a lift on your truck your tires need to stick out a bit imo
Old 04-28-2010, 08:07 PM
Get the 10s for sure.
