Auxillary Fuel Tanks - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-27-2010, 10:34 AM Thread Starter
Have '09 F450 and need to add some more fuel capacity. Thought I'd replace the stock tank with Aero 62 gal then put in bed tank between 75-100gals, either pump fill or gravity fill. suggestions/information greatly appreciated.
Rockhead
Rockhead40 is offline
post #2 of 15 Old 04-27-2010, 11:12 AM
shaking things up
jethro's Avatar
that is alot of fuel i think that would work fine i would not hard pipe the aux tank in bed to the fuel tank that way if you need to remove it you can
389.14 HP 726.00 TQ
96 f-350 7.3 with a 5 speed
3 in DP
4 in ex. to 5 in aussies
custom traction bars
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
custom fuel with an AIRDOG 2
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
facebook- Graham Maxwell
jethro is offline
post #3 of 15 Old 04-27-2010, 12:07 PM Thread Starter
Yep, but we have a 39' toyhauler to tote as well as a gooseneck. With fuel prices jumping around like it does-you find a good price you want to get as much as you can!! Besides-fueling up once a month or so would be great !!
Rockhead
post #4 of 15 Old 04-27-2010, 12:11 PM
1tonpower's Avatar
Send a message via AIM to 1tonpower
use quick connect fittings if you ever have to remove the tank for anything. gravid works fine. im still in the thought process of what i want to do with mine.
if i go with a bed mounted tank i will it plumb it into the main tank. and ill have an in-line pump with a fuel water separator between the main tank and the bed tank. i need to think up some way to wire in a safety so the main tank doesnt over flow.
thanks what i got..take it how you will...keep up posted on what you end up doing
08 f350 KMC wheels with 33" MTZs, bed rails with a reese 20k slider, 5% tint all around, 60gal fuel box, kenwood monitor, afe drop in filter, livewire w/innovative tunes, sinister egr delete, twisted stage 3 trans
1tonpower is offline
post #5 of 15 Old 04-27-2010, 12:23 PM Thread Starter
Have you looked at ATTA.com with thier two styles of feeding fuel? They have an "automatic"system and one that works on a mometary switch.
Rockhead
post #6 of 15 Old 04-27-2010, 12:39 PM
SuperCrutyPS's Avatar
Quoted: 305 Post(s)
Garage
Have you looked here?
Ford Large Capacity Diesel Fuel Tanks for Pickup Trucks ~ TITAN Diesel Fuel Tanks: The Leader in Aftermarket Fuel Tanks
Many of them fit in place of the stock tank, keeping your bed free. Haven't used them, but have been researching because I pull a 5er and wouldn't mind the extra capacity.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #7 of 15 Old 04-27-2010, 01:00 PM Thread Starter
No, I hadn't until now, thanks. I'll contact them to see if they fit the F450. I've been looking at these: AeroTanks-we specialize in auxiliary fuel tanks.
The FSD62L is the one I'm most interested, then I'm going into an in-bed model, still doing more research on those.
Rockhead
post #8 of 15 Old 04-27-2010, 01:45 PM
1tonpower's Avatar
i assume you have a pick up 450 and not a C&C..you could probably mount a 2nd tank where you spare tire would be..it would be a little bit of work to set it up though
post #9 of 15 Old 04-27-2010, 02:02 PM Thread Starter
I've looked at those also-about a 40 gal is what I've been able to find. Not too keen on having that weight behind the axle and tow a load-sure it could handle it not sre what that would do to the ride.
Rockhead
post #10 of 15 Old 04-27-2010, 05:13 PM Thread Starter
And never thought of using quick connectors on the lines 1ton-great idea.
Rockhead
