put f350 blocks and 1.5 lift on my truck! got ? - Ford Powerstroke Diesel Forum
Old 04-26-2010, 02:18 PM
Hey i put f350 blocks in my f250 and 1.5 inch lift in the front. my question is do i need a carrier bearing spacer. it might have a tiny vibration once and awhile. what are you guys doing with your trucks. thanks
Old 04-26-2010, 02:25 PM
If you decide you want one, let me know. I got the ReadyLift sst kit for my truck, which comes with the carrier bearing spacer, but my SuperCab has no carrier bearing. So, if you need one I'm sure I can help ya out.
Old 04-26-2010, 05:36 PM
I put a 2.5 inch Icon kit with 3 inch blocks in my truck and no shudder. I installed new 35x12 Toyos which are about one inch taller then the stock 20's and I got a shudder on acceleration. Put about 3/4 inch spacer on the carrier and shudder is gone.
Old 04-26-2010, 05:53 PM
I put the ICON 2.5" setup with 4" blocks in the back of my 250 and got a pretty good vibration from 12-22 mph. I had to shim out about an inch to get the vibe to quit. I'm running the stocker tires though. Make sure to upgrade to Grade 8 hardware while you're at it...
