| 6.4 Exterior Discussion Body and Accessories Talk |
Head Lights
I just put in HID's and I was wondering if I can turn off the function that turns the headlights on when you unlock the truck?
Thanks. |
This is out of the manual for my 09 F350. Looks like you can do it yourself if you have power locks. Hope it helps.
Deactivating/activating perimeter lamps illuminated entry You may enable/disable this feature by having your vehicle serviced by your authorized dealer. You may also perform the following power door lock sequence to enable/disable the perimeter lamps feature. Note: Before starting, ensure the ignition is in the off position and all vehicle doors are closed. You must complete Steps 1–5 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, wait a minimum of 30 seconds before beginning again. 1. Place the key in the ignition and turn the ignition to the on position. 2. Press the power door unlock control on the door panel three times. 3. Turn the ignition from the on position to the off position. 4. Press the power door unlock control on the door panel three times. 5. Turn the ignition back to the on position. The horn will chirp one time to confirm programming mode has been entered and is active. 6. Press the power door unlock control twice within 5 seconds. Note: The horn will chirp once to indicate the perimeter lighting feature has been deactivated. The horn will chirp once and honk once (one short and one long) to indicate the perimeter lighting feature has been activated. 7. Turn the ignition to the off position to exit the procedure. Note: The horn will chirp once to confirm the procedure is complete. |
That seemed to work.
Thanks. |
