Train horn help!!! - Ford Powerstroke Diesel Forum
Old 03-11-2010, 01:02 PM
Send a message via Yahoo to skipnay
Train horn help!!!
Looking into getting a set of Horns. I like the K3LA's!!! Is it worth the money to buy the expensive ones or just cheap train horns? I actually have 2 five gallon tanks as of right now off of offroad trucks. Just need to put them on my truck. Would also like to use my air for air bags and inflate tires to toys like ATV's and such... So what would you go with?
Here is what I was thinking for parts:
Dual Pewter Viair 480C Air Compressor Kit (480)
Constant Duty, 200 PSI, 100% Duty, 3.53 CFM
Low Price: $379.95
or
Air Zenith OB2 Air Compressor
Constant Duty, 200 PSI, 100% Duty, 3.8 CFM
Low Price: $349.99
Plus I will probably go with bigger air lines. The bigger the better right? Give me your 101. Pro's and con's of your system and what you would and wouldn't change if you had to do it all over again...
Old 03-11-2010, 02:41 PM
Here is what I would do. I would get the viair compressors, 200 psi pressure switch, run 3/8 valve and line and the kl3 horns. That will be sick.
I have basically that setup but I have two sets of triple trumpet chrome horns and only 6 gallons of air.
Old 03-11-2010, 02:49 PM
My set up is no where as nice as what your looking into. I have Omega Triple Trains ran at 150psi. 2 gallon tank, 3/8'' lines. The only thing i would change is to 1/2'' line and a larger tank.
Old 03-11-2010, 02:52 PM
K5LA's and 1/2" line with a converted York A/C compressor when I redo mine.
My ear drums hurt thinking about that set up
Old 03-11-2010, 03:33 PM
I have a k5h that i have not installed yet and viair dual 480's with a 5gal. tank 200psi 1/2" line and valve i think it will be loud enough!!!
Chris
Old 03-11-2010, 03:36 PM
I would say so!
Old 03-12-2010, 11:12 AM
Where did you guys gets your stuff from? Actually buying the parts separate might be more expensive but this way I can get what I want and need instead of a bunch of wasted stuff that I may not want or need.
Old 03-12-2010, 11:23 AM
I pieced mine. Got the horns from ebay, the tank is off a wheelbarrow compressor and the compressor (not mounted yet) is a York A/C compressor off of a 70's Chrysler
Old 03-12-2010, 11:24 AM
There are also some vendors that sell kits on here.
