PSI in Toyo MT's? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-21-2010, 01:48 PM Thread Starter
fx4superduty33's Avatar
PSI in Toyo MT's?
I just got 35x12.5x20 Toyo MT's for my 2008 FX4 ccab shortbox.They r a 10 ply tire, what PSI should i run? My door tag says 65psi in front and rear.
ID:	13080   Click image for larger version
ID:	13081   Click image for larger version
ID:	13082   Click image for larger version
fx4superduty33 is offline
post #2 of 9 Old 02-21-2010, 01:59 PM
supreme oppressor's Avatar
I was just wondering that myself. I found the following on Toyo's site, but of course they don't list the 35x12.5x20 - use the ones with the closest max at 65, then adjust for load. They tend to wear in the middle if inflated to the max and truck is empty.
http://toyotires.com/sites/default/f...ationtable.pdf
2006 F350 6.0 CrewCab Fx4 - Leveled & 35" Nitto's
2002 Subaru WRX
1983 Kawasaki GPz750 with the 810 big bore kit, parked.
supreme oppressor is offline
post #3 of 9 Old 02-21-2010, 03:44 PM
02stroker250's Avatar
hey man you do you got a whole side shot of your truck with them rims and tires on there?
2005 F-250 ccsb fx4
02stroker250 is offline
post #4 of 9 Old 02-21-2010, 05:15 PM
smotrs's Avatar
I found these on Toyo's website,
Code:
                                         Approved Rim     Tire     Tread    Overall     Overall    Static          Max Load:   Max Load:   Max. Pressure   Max. Pressure:
                           Product       Width Range      Weight   Depth    Diameter    Width      Loaded Radius   Single      Dual        Single          Dual                      Revs        Tread           Sidewall
Tire Size                  Code          (inch)           (lbs.)   (1/32")  (inch)      (inch)     (inch)          (lbs)       (lbs)       (psi)           (psi)            UTQG     Per Mile    Constuction     Construction
35X12.50R20LT 121Q E/10    360240        8.5-10.0-11.0    80.5     21       35          13         16.3            3195         N/A        65              N/A              N/A      592         3P+2S+2N        3P
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT's
Avic-Z2 Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, Six-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares
Ravelco Anti Theft Device
Originally Posted by Rick Santorum
We went into a recession in 2008 because of gasoline prices.
smotrs is offline
post #5 of 9 Old 02-21-2010, 05:17 PM
choupique108's Avatar
read on the tire. It tells you what its rated for
1997 Single Cab Dually, S366 w/ Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s, Corbeau seats w 08 console, 19.5s, 6637, Black Interior with swede headliner and visors, Custom badges, Flight Fab Traction Bars.
choupique108 is offline
post #6 of 9 Old 02-22-2010, 02:57 PM
tucker's Avatar
Lets see some pics of the truck with those rims.
2008 FX F-250 with ICON leveling kit
tucker is offline
post #7 of 9 Old 02-22-2010, 04:11 PM Thread Starter
These r the best pics i got, i'll get better or ones of the whole truck tomorrow.
ID:	13102   Click image for larger version
ID:	13103   Click image for larger version
ID:	13104   Click image for larger version
post #8 of 9 Old 11-21-2014, 02:25 PM
hogsontheroad's Avatar
Quoted: 3 Post(s)
I have these same tires on my f350 so according to the chart provided I should keep the pressure at 65lbs. Truck is stock and I won't be towing that often. Any help/advice would be appreciated
hogsontheroad is offline
post #9 of 9 Old 11-22-2014, 02:27 AM
Quoted: 3 Post(s)
Hey Guys. Is 60lbs all the way around a good psi for these tires on my f350? Any help would be appreciated. I don't want to underinflate/overinflate these tires.
