| 6.4 Exterior Discussion Body and Accessories Talk |
20x10 -12 wheels?
I am looking at some xd wheels that are 20x10 with a 5" backspace and -12 offset how far are these going to stick out i plan on running a a/t tire probably 355/60/20 once i lift it anyone running this setup pics??
thanks, Chris |
Nobody running a similar wheel /tire combo?
Chris
My KMC Monster's are that size with a 38x15.50 tire. Here's a pic for reference:
![]() Here is a pic when I was running 37x13.50s.
Thanks jrod how far would you say the 37's stuck out past the fenders wondering if some pocket flares would cover them.
Chris |
I have 20x9 Xd hoss's with 4.5 BS and -12 offset. Heres some shots to give you and idea. Tires are 38-15.50-20
Looks like they stick out pretty far i don't think the 2 1/4" flare would cover them but you are running 15.50's the ones i would run are 14"s but the rims are 1" wider still should be a little narrower.
Chris |
To be honest I can't remember how many inches they stuck out with 37s but I would guess the pocket flares would cover most of the them....they didn't stick out nearly as far as my 38s.
I'm thinking the same 37's and 355's are almost the same in size i am stil looking at the bmf wheels they are -19 so the may be a bit more out. did the 37's rub the radius arms at full lock with the monsters?
Chris |
Nope I didn't have any rubbing at all with them.
I have 20x12 wheels 4.5 bs and no flares they stick out about a good 4"-4.5" pass the fenders. Also with an 8" lift 15.5 tire with a little flex and the wheel turned I rub the inner carpet fender well not a big deal but you can hear it
