| 6.4 Exterior Discussion Body and Accessories Talk |
dual steering stabilizers
i am throwing around the idea about putting dual steering stabilizer on my truck since i am running 35's and fixing to run 37's on my truck will the dual stabilzers help with the shake in the steering wheel and better handling
Yeah if you do have a bad shake it will help correct the problem. After I got my lift put on ( 8 inch, 37 toyo x 22 inch wheel) I brought it to an alignment shop and after they messed with it. I had no shake at all after that and didn't need to buy steering stabilizers.
Have you lifted it? Additional castor is needed with these trucks.
it wil help a lil bit...
i but a 2.5 leveling kit and 4 inch blocks in the back and im fixing to put some bigger coilsprings on there they will be 1.5inches taller than stock coil springs
are you going to stack the 2.5" spacer on top of the new coil springs?
yep thats my plan or take or take them out and put new 4.5 coilsprings under under it cause im going to 37's
well are you going to get any of the rest of the stuff you need like an adjustable trac bar, longer shocks? there is a reason they dont make a 4" leveling kit.. you cant just slap a longer coil with a coil spacer and expect it all to work... just my opinion though to each their own
-Raul |
well i have already bought longer shocks when i put the leveling kit on and i plan on putting aftermarket trac bars on it to
Better do something about the huge lose of castor..drop brackets.
