No lift and 35's on 22's ? - Ford Powerstroke Diesel Forum
Old 11-25-2009, 03:52 PM
I have decided to wait and save money for the 4 link 8" fabtech kit but for now I have 22" ultras with a 5.75 in backspace on a 10" wide wheel and would like to know if i can put these on my stock 09 f-350 with 35" toyo MT. Anyobody know the answer to this before I buy tires.
Best,
James
Old 11-25-2009, 03:53 PM
My f-350 has a camper package if that makes a difference
Old 11-25-2009, 04:18 PM
Should fit, may need a leveling kit, but I think they will fit. If you do it, post up pictures cause I want to see what the 35" toyos look like with 22s.
Old 11-25-2009, 04:24 PM
matt I will post up pics afterwards if they fit. but I don't want to order tires until I know for sure they will fit. Also don't want to spend money on a leveling that could be going towards purchasing my 8" fabtech. And I here to many bad things about the leveling kits unless you do all the upgrades to them then it's as much as a full lift kit. do you know what the stock backspacing is?
Old 11-25-2009, 04:46 PM
In my opinion that's a pretty wide wheel and big tire to put on there with no leveling kit. Could fit though...hopefully someone with a similar setup can chime in!
Old 11-25-2009, 04:49 PM
I have a leveling kit and 20's on my truck with 33's and had to cut the inner wheel well... Not a big deal, a box cutter will do the work.
Old 11-26-2009, 08:13 AM
Send a message via AIM to speeddemon619
Alot has to do with your offset and whatnot. May fit or may not without some hacking. Post up some pictures, Id like to see it!
Old 11-27-2009, 11:38 AM
Guys run 35s with 20x10s with a 4.5 backspace all the time. Your wheels aren't going to stick out as far. About 1.25 inches less. You'll be fine, except for a little rubbing on the inner wheel well. I'm pretty positive you'll be fine.
Old 11-27-2009, 11:59 AM
running 20's 4.5 backspace and -25 offset. i have toyo mt 35s. the tires do not rub but they are almost at the end of their life. i think when i get new ones, they're gonna rub.
Old 12-06-2009, 02:19 PM
everything worked and I think it looks great. What I don't understand is why everyone is wasting money on a leveling kit when you can put 35" toyo m/t with out it. seems like for a leveling kit with all the parts to make it a good reliable kit will cost you $800-$1000 with cams, and pan rod new coils and shocks etc. better off to put on the tires with out the leveling kit and spend the money on a spartan. also with the new tires the truck looks more level already. to see the pics goto ...
