tire rub with 37's - Ford Powerstroke Diesel Forum
Old 11-24-2009, 04:50 PM
tire rub with 37's
Hello to all, i just had toyo open country m/t 37x13.50x20 installed on my truck and the tire is rubbing the arm at full turn. i am getting a 6" lift in the beginningof the year, will this fix the rub. also should i get wheel spacers and if so how thick. thanks
Old 11-24-2009, 10:29 PM
totally depends on which wheels you run
Old 11-24-2009, 10:43 PM
is it only rubbing one arm???
Old 11-25-2009, 06:54 AM
The wheels are stock 20s. It's rubbing on both when you turn the wheel at full lock
Old 11-25-2009, 07:09 AM
its your wheels.... your tires are too wide for those stock wheels.... you need a diff wheel that are wider and that have the right offset...
Old 11-25-2009, 01:11 PM
Today I cut a chuck of the fender well out for clearence and that worked good. I can live with the rubbing I have now. The tire rubbing against the fender well is what was annoying. Now it is time to start looking for a lift kit.
Old 03-06-2010, 11:29 PM
Send a message via Skype™ to mattyl
can u get 37's under a 08 4x4 1ton duell with a 6 inch lift with no problems it seems that the 08's look like they sit lower stock them most of the previous years or the other manufactures..
Old 03-07-2010, 03:43 PM
Even with the lift it will still rub at full lock, but that's all. I very rarely rub mine because I've gotten so adjusted to not turning my wheel all the way. I have contemplated on new wheels many times, but keep going back to the look of the factory 20's and the fact that they don't stick out as far and chunk rocks all over my truck. Just my .02
Old 03-07-2010, 06:56 PM
mine rub too, 6 inch pro comp with 37s and monster rims,
Old 03-07-2010, 07:04 PM
What bout 2'' wheel spacers do they make them that lug pattern yet? That would fix it.
