rear springs or blocks?? - Ford Powerstroke Diesel Forum
Old 10-26-2009, 06:49 PM
i have been checking out some lifts that i might do but wondering if i should do springs or blocks in the rear. i am looking at the rize 6" kit and they have a set of soft ride rear springs i know most like blocks to keep a good ride anyone running the rize springs and hows the ride or should i run some ouo traction blocks and bars?
Chris
Old 10-26-2009, 08:25 PM
Chris
last I remembered Rize springs are Atlas rear leafs. I personally like the idea of the OUO tractions blocks. aprox $1400.00
Old 10-26-2009, 08:49 PM
OUO traction blocks are the best bet, especially if you are tuned. With just taller blocks you will see more axle wrap. With new springs you won't see more axle wrap but you will ride stiffer or lose weight capacity depending on which rear spring you go with. Plus rear springs for the '08s aren't much cheaper than the OUOs. With the OUO setup you keep stock ride and weight capacity and also eliminate the potential for any axle wrap.
Old 10-27-2009, 04:33 AM
That was a concern for the axle wrap with a 6" also and yes it will be spatanized soon hopefully. i do like the ouo setup little pricey but looks very functional.
Chris
