| 6.4 Exterior Discussion Body and Accessories Talk |
Change it up?
Alright, I need some help here. I recently put on a 4.5 Icon, 20x10's with some 35" Toyo MT's. I just got my territory for work moved. I am now traveling about 250 miles a day round trip. I am worried that these tires are gonna get smoked with the quickness. Another problem is that the wheels have a 4.5 backspacing on them. This kicks up a lot of dirt on the truck. (Driving me INSANE). I am thinking of changing the wheel setup and need a little more information.
I am thinking of putting a TEI spacer in the front. I want to run a Nitto Terra Grappler. I think a 37" would do good. (Most people told me to run a 37" before I got the 35's) Also I want the wheels to tuck in the wells a little more so I don't get as much dirt and debris on the truck. The only thing I can find similar to what I want is 10.5's truck below. ![]() I am trying to find out if the TEI will give me enough clearance in the front and if the 5" block in the back is enough. Also, what backspacing would I need to acquire the same look? Or am I just getting the itch to do something else and need to keep the truck just the way it is. Here is the current setup.
I think the Toyo's Wear Great!
Just make sure you Rotate them as Suggested. I've put 25,000 on them easily. I bought my Truck with them, so I don't know how many miles are on 'em before me. Just stay off the Throttle if you are "Tuned". They are Expensive to Burn Off! |
Rims are too wide not cause of backset. If you don't want them to protrude go to a narrower rim/ tire. Some guys run 37's w/ only a level kit, but you won't be doing any offroading, thats for sure. Lastly Nittos will wear twice as fast as Toyos! If you have to have the wide rim /tire look investigate fender flares or chip guards.
I have seen alot of guys run a 37 on a small lift. I was wondering if I would achieve the same look as 10.5's with the TEI spacer and my 5" block. Just want to keep the same distance between the fenders and the 37's as I do with the 35's. I believe he is running a 6" Procomp but I don't know what block he has in the back. I don't know if I should also just kick up the back to a 6" block.
Any Suggestions?
IMO The BMF wheels have the perfect offset for lifts under 6" and they don't still out very far at all. I had them in the 20x9 flavor on 37's with just a leveling kit and no rubbing. I also just happen to have a set for sale in that size as well from when before I lifted my truck.
Jesse...Do you have a shot of the sides... kinda like this
I looked but I don't. They aren't mounted anymore because I swapped them out for 20x10s
Are they an 18 offset? I am beginning to think that is what I am looking for..... I think.....
