Cab llight Question about wiring - Ford Powerstroke Diesel Forum
Old 10-19-2009, 02:16 PM
dc4 dc4 is offline
I bought a pacer cab light kit, after installing the actual lights I ran into a problem getting them wired up. The kit only came with one long wire and a switch. Does anyone know where I could run that wire to get power to the lights.
Old 10-19-2009, 03:24 PM
I used the factory Ford cab light set and found the factory plug in right behind the headlight switch..just pull off the drivers side dash cover and you should be able to locate it...good luck
