Anyone have pics of toyo 37" tires on factory 20" wheels?????? - Ford Powerstroke Diesel Forum
Old 08-11-2009, 12:48 PM
wanting to put a set on my truck but would like to see a pic of them first. thanks
Old 08-11-2009, 12:50 PM
Let's Run'em
I'm thinking your stock 20" is going to be too narrow for a 37" tire
Old 08-11-2009, 12:57 PM
37's will fit on stock 20's...
Old 08-11-2009, 01:00 PM
ive seen other brands of 37 tires on the stock wheels, but i want the toyo m/t tire
Old 08-11-2009, 01:01 PM
Let's Run'em
I'm not saying they won't physically fit, cuz they will, I was referring more to the fact that most 37" tires are at least 13" wide and with a 7" wide rim your going to get lot of bounce and ballooning in the tire then if you went with the correct wheel size, not to mention heavier wear on the center section of the tread of the tire
Old 08-11-2009, 01:04 PM
Let's Run'em
There is a reason that Toyo even recommends a wider rim with the 37s
OPEN COUNTRY M/T | Toyo Tires
Old 08-11-2009, 01:19 PM
the stock rims are 8" wide
Old 08-11-2009, 01:22 PM
Let's Run'em
.......ok
I don't know of any members that are running that kind of set up, but one maybe along shortly
Old 08-11-2009, 01:25 PM
i have a 35x12.50 on factory rims and thats pushin it
Old 08-11-2009, 01:29 PM
well i have run 35x12.50 toyos in the past and they ran fine and right now i have 325/60r20 bfg all terrian on my truck and they are a 13 inch wide tire. so i wasnt asking if it would work i know it will work, i just wanted to see some pics of how they look on the factory rim. thanks guys
