| 6.4 Exterior Discussion Body and Accessories Talk |
need help on rim offset choice
i am about to buy a set of 20x9 jesse james lawless 8 +12 offset. what will these look like compared to stock 20s. will they have a dish or lip at all? like how far will they stick out vs stock? or should i go with the 20x10 with -43 off set. i dont want them to stick out crazy far like a roller skate look.i have an 2008 f 350 with 2 inch leveling kit. 35-12.50-20 toyo mt.
20x9 with +12mm offset is 5.5" Back Space. They will stick out 1-1.5" further than the stock wheels.
20x10 with -43m offset is approx 3.81" Back Space. These would stick out approx. 4" further than stock wheels....and may have some rubbing issues with only a 2" lift. |
Negative numbers will give you a bigger/deeper dish positive numbers will give a smaller/shallower dish. The wheels I have are -24 and the tires are 35's, this combination makes the tire stick out about 1-1/2 inches on my truck.
Not sure what the offset is on the stock wheels, my guess is that the 20x9 (+12) will be about flush with the fender well, give or take a PH. BTW, offsets are measured in millimeters. |
DC, is 5-1/2" correct? Sounds high to me.
i cant find a picture of them any where. like to see what the rim looks like on truck
This is what mine look like, wheels are 18x9.5 (-24).
Yep, 9" wide +12mm offset equals 5.5" Back Space. Only way to get less Back Space with the given +12mm offset would be with a skinnier wheel. If it was 8" wide it would be a 5.0" Back Space. |
Hmm, ok. Thanks for clarifying.
you guys are talking in japanise. i just was wondering if its going to have a little wider stance than stock. i dont like the flush rim look. but i dont want a real deep dish either that sticks way out
TruckToyz Performance Image Viewer
Those are the same spec wheels you are looking at. If I could have found a set, I would of ran them, but all I could find were 20x10s with the -43 offset. |
