Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
Old 06-28-2009, 05:35 PM
08FX4RBP 08FX4RBP is offline
Max Tire Size w/ Snow Plow Package?
Does anyone know the max tire size with having the snow plow package on your truck? Im going to re-use my factory 20*8 rims for now and just run a bigger tire if possible.
Thanks in Advance!
Old 06-30-2009, 07:46 PM
RamAirfreak98ss RamAirfreak98ss is offline
Thanks in Advance!
guys plow with the factory 20s.. you can use any tire/wheel combo you want, as long as its nothing extreme like 37s+ because then you need to get custom plow mount brackets fabbed up so the front mount hangs down low.
Our boss plows state the mount hooks need to be 15" off the ground, yet you will be ok at 14-16", anything higher and your gonna have a *****in time hooking the plow up.
