Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
Old 06-27-2009, 07:24 AM
rjd52078 rjd52078 is offline
Send a message via AIM to rjd52078
new here have a question for you
hello everyone im new on here and just purchased my first 09 f350 6.4 ..all ready have the s&b cai, spartan , and dpf/cat delete pipe my questions is what is the biggest sized tires i can put on without lifting this truck , i was thinking about just getting a leveling kit, but i dont want to go any higher(just yet) cause i need to put equipement in the back of it all the time. just dont want to go bigger and have a rubbing issues. thanks for all you input in advanced
Old 06-27-2009, 07:39 AM
InMotionJosh InMotionJosh is offline
You can squeeze a 35" tire on the truck with no leveling kit. You can squeeze a 37 on with a leveling kit altough i dont recomend either.
I think the best choice is a 35 with a leveling kit.
Old 06-27-2009, 07:48 AM
ok thanks they make a 35" to fit on the stock 20"rim??? and if i get the tires first and then the leveling kit i should be ok for a little bit? will it rub or just when i turn the wheel all the way in
Old 06-27-2009, 12:01 PM
matt05 matt05 is offline
No, maybe on your radius arms, but a lift won't fix that.
Old 06-27-2009, 02:01 PM
jpfitz55 jpfitz55 is offline
I have 35" tires on my truck with no lift and i only rub at full lock in reverse. I would recommend a leveling kit though. Good Luck
Old 06-27-2009, 02:25 PM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
I say 35's with a leveling kit!
Old 06-27-2009, 02:48 PM
smotrs smotrs is offline
Yeah, if your looking for very minimal, then 35's with the leveling would be it.
Old 06-29-2009, 05:57 PM
ok so 35's with a leveling kit, or what 33's without leveling kit, and as far as leveling kits goes which one does everyone recommend and how hard are they to put in on my driveway?
Old 06-29-2009, 08:01 PM
33's are the equivalent of the standard tire that's provided on the truck before doing wheel upgrades.
To give you an example, the stock tires on my truck were 275/70R18 this computes out to the equivalent of a 33.15" tire size.
Old 06-29-2009, 08:16 PM
BTW, take a look at the following thread for an example of 37's on a stock truck with nothing but a leveling kit.
37x13.50x20 on BMF 20x9 with Leveling Kit Only
