Traction Bars - Ford Powerstroke Diesel Forum
Old 06-23-2009, 04:33 PM
Traction Bars
I'm sure this has been discussed before but here goes...Whats the best traction bars out there for the money? I have the carrier bearing drop kit and my truck stills vibrates a little on a take off. I would like them for other obvious reasons also. I really like the OUO bars with the blocks but they aint cheap. Anybody else tried other brands? Good/Bad?
Old 06-23-2009, 04:36 PM
One up Offroad is the best... here is a link to another thread
spartan and lifted trucks
Old 06-23-2009, 04:39 PM
Get ahold of dan and trucktoys
(dcspecial) he'll hook you up cool dude
OUO does have plain traction bars as well....without the blocks.
Either with a bolt on or weld on mount for the axle. The frame mounts are all bolt on.
What are the specs on your truck? cab and bed config? lift?
Old 06-23-2009, 04:41 PM
traction bars alone may get rid of the vibration withough the carrier bearing drop.
Old 06-23-2009, 04:43 PM
It's a crew cab short bed, 4x4, 6" pro comp lift, 37" toyos, and I kinda want to get rid of the stacked blocks and add-a-leafs in the rear.
Old 06-23-2009, 04:51 PM
Ah...then yeah traction blocks are the way to go
We do have 90 days 0% on all purchases using the Truck Toyz/Car Car One card (or if you already have a Car Care One card).
Old 06-23-2009, 04:57 PM
Thanks. Shouldn't be too much longer. Couple days of OT at work and I should be good to go. I'll definately shoot you a PM
Old 06-23-2009, 07:24 PM
I looked at that car care card thing and it said the rate was like 19 something...what the frick.
Old 06-23-2009, 08:01 PM
That's all handled by GE Money Bank.....I've only ever used it over the years to take advantage of the 0%.
