Fuel sender unit?? - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 2 Old 05-04-2014, 09:43 AM Thread Starter
Fuel sender unit??
My fuel gauge is reading below empty constantly. It won't move. It actually moves up to the "E" mark when I turn the truck off. But once I turn it on, the needle goes further then the "E" mark. So any ideas where to start? How does the gauge get its reading? Is there a fuse? I just need to start somewhere. Thanks.
09powerstrokee is offline
post #2 of 2 Old 05-04-2014, 09:51 AM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
Fuel senders operate off resistance, higher resistance when there's more fuel in the tank, so you have a short. Check the wiring harness going to the tank and sender under the truck. Maybe it got scraped or rubbed open, or the plug on the top came loose or got crushed if the bed was overloaded, etc. I also had a gauge go crazy once when I had some insulation push up on the harness on the back of the instrument panel, moved the insulator and it returned to normal. Good luck.
2002 F-250 LARIAT CCSB 7.3 AUTO 4X4 261,XXX
2004 EXPLORER XLT 4.0 AUTO 2WD 130,XXX
1966 MUSTANG COUPE 289 4 brl V8
IN-LAWS...
2004 EXPLORER SPORT TRAC 4.0 4X2 100,XXX
2004 F-250 RCLB 6.0 AUTO 4X2 38X,XXX
2005 F-250 RCLB 6.0 AUTO 4x2 36X,XXX
SOLD... 3 RANGERS, 3 F-150s, 3 F-250s, 96 COUGAR 4.6, 99 EXPEDITION 5.4, 65 66 AND 69 MUSTANGS
RE-ASSIGNED... MULTIPLE FORD POLICE INTERCEPTORS
AU7POINT3 is offline
