Uplifter problem - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 6 Old 04-25-2014, 08:14 AM Thread Starter
Uplifter problem
Hey all,
I have a 2008 f250 6.4 as a work truck.. On my uplifter switches i had a high idle installed on switch number 1 and a backup beeper installed on switch number 4.. I just installed a 21" led light bar in my bumper. Wired it to 1 of the 4 wires that go through the firewall and under the dash. From there in tried to wire it into one of the 2 remaining uplifter switches but when i touch the wires together it turns the light bar on regardless if the switch is on or off, but shuts off when i turn my key off.. Any ideas?
Adrian94 is offline
post #2 of 6 Old 04-25-2014, 08:20 AM
ZMANN's Avatar
Quoted: 1464 Post(s)
upfitter is the term
check the switch output sounds like you have the feed from the box to the switch vs the switch output used ? or the switch is faulty ?
We Miss you Ronnie
ZMANN is offline
post #3 of 6 Old 04-25-2014, 08:22 AM
ZMANN's Avatar
ps those 4 wires that are the "pass through wires" are not hooked up at the factory to the upfitters so that may be your issue they are "blunt cut" and user terminated to whatever the end user wants
We Miss you Ronnie
ZMANN is offline
post #4 of 6 Old 04-25-2014, 10:29 AM
fordmanmark1's Avatar
Be sure u didn't accidentally hook the wires to the other blunt connectors that are feed to PTO and such, some of those are hot when the key is turned on .
2015 F-350 Platnum FX4 Superduty 4X4 6.7L crew cab Longbed 3.55's 5th wheel prep
Old truck's 95' 7.3 LB EXT 4X4 285,000 miles very much Missed! 08' F-250 6.4 fully deleted
Lots of mods to come
Quote:The right of the people to bear arms shall not be infringed.
fordmanmark1 is offline
post #5 of 6 Old 04-25-2014, 11:14 AM
jcook933@gmail.com's Avatar
Also check your upfitter relays. There is one for each switch.
BEASTPSD
jcook933@gmail.com is offline
post #6 of 6 Old 04-25-2014, 01:57 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
just to be clear the upfitter switch wires arent with the bundle of capped wires down low. they are up a little higher and there are only 4 wires coming out of a wire loom and i believe they even say aux number and amperage on the tag. just make sure youve got it wired right. ive never had an issue with all 5 of our trucks upfitters. very reliable system i think
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
