OEM CD player with NAV problem - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 2 Old 04-10-2014, 11:49 AM Thread Starter
xotic_illusions's Avatar
Truck is an 08 f450
My Factory stereo with 6 Disk in dash CD/ NAV has 6 CD's loaded and they will not come out. When I hit eject and choose a disk to eject, it just waits about 20 seconds then says CD ERROR....
Any ideas?
2008 6.4 TT F-450 Crew Cab 4x4 Dually
xotic_illusions is offline
post #2 of 2 Old 04-10-2014, 01:21 PM Thread Starter
I found the problem! had an extra disk shoved in. You can remove the radio, then there are 2 screws to take out. on the top cover, Then the top cover pops off. If you look from the top the whole 6 disk changer unit come ofutwith 4 screws, then you remove the ribbon cable. Pretty self explanatory from there. If anyone has this issue I hope this helps!
