TBC " wiring fault on trailer " error - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 7 Old 03-13-2014, 02:12 PM Thread Starter
Hello I have this fault on my dash. I checked all fuses and there good. I have power on all of the 7 and 4 connectors on the plugs when activated so no problem there. Having searched on here it sounds like most people say it's water or corrosion on the plug so I pulled that and there is no corrosion and it was stuffed with die-electric grease. I'm wondering what others have done to fix this? Some have replaced plug but I hate to waste $30 if that's not going to fix the problem. what else can I check/try to fix this. Or if you've had this what did you do to fix it that worked?
pointman7881 is offline
post #2 of 7 Old 03-15-2014, 02:26 PM Thread Starter
Nobody has had this problem? Even if you had this problem fixed under warranty I'd like to know what took care of it.
post #3 of 7 Old 03-15-2014, 02:50 PM
Alberta Advantage's Avatar
Quoted: 19 Post(s)
I had the error come up once and I just unplugged the trailer and then plugged it back in and it went away. I'm guessing it was just a bad connection or something. Seems like factory brake controllers on any trucks are problematic.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #4 of 7 Old 03-16-2014, 06:13 PM Thread Starter
Thanks Alberta but mine is doing this with no trailer connected. Which means it's something truck related I think I'm going to just buy a new plug for the rear and see if that takes care of the problem.
post #5 of 7 Old 03-20-2014, 06:16 PM
jcook933@gmail.com's Avatar
Hey pointman I can pm you a pin out test for the fault. Some of it requires the IDS but there are some tests you should be able to do yourself if that would help.
BEASTPSD
jcook933@gmail.com is offline
post #6 of 7 Old 03-20-2014, 08:51 PM Thread Starter
jcook sounds good I don't have IDS would a snap on modis be able to test for anything? otherwise I'd have to take it to the dealer and that's $95 minimum. Send me what you have and hopefully it will help me get this figured out. thanks
post #7 of 7 Old 03-22-2014, 04:35 PM
I have had the same code. Mine had water inside the 7 pin connecter housing. I took it apart and cleaned it with electrical cleaner. The fault never came back until last week when I was power washing the underside. Opened the housing up again...full of water.Cleaned it again, code gone. I could still tow with no issues with the trailer.
SOLD! 00 F-250 CCSB 4x4
4" TB Exhaust, K&N Fipk, Evolution 2, Boost Annihilator,
SS HPX line, Foil Delete, Wicked Wheel, 2" Leveling Kit,
300K miles and still going strong!
2008 F-350 CC Lariat 4x4
wooby99 is offline
