12 Vdc outlet in the bed - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 4 Old 03-11-2014, 02:20 PM Thread Starter
Toy Hauler
Quoted: 2 Post(s)
I searched but no luck. I need to add a 12 VDC cigarette type outlet in my bed.
I want to run the Hot from the battery... what is the best way... can I through cab and then to bed or should I just run all underneath and drill hole up into bed?
I have an 09 crewcab... I have run outlets before in my jeeps and such but not to bed of truck. My Titan had one installed from factory
f250intx is offline
post #2 of 4 Old 03-14-2014, 07:46 PM
Military Member
cpepper5702's Avatar
I don't see why you couldn't run it along the frame of the truck using zip ties then depending where it's at go from there. I'd assume your putting it near the tailgate? I would stay away from running it through the cab. HUGE head ache bud...
- Colton
New Purchase:
2008 F250 FX4 6.4 POWERSTROKE
Bone Stock (for now)
--- SOLD ---
2005 F250 Lariat FX4 6.0 POWERSTROKE
SCT Tuner w/Custom Tunes
Upgraded Fuel Pressure Regulator
aFe Stage II Air Intake
Straight Pipe Exhaust
2003 Turbo "Got Whistle?"
Sold after putting $5k+ in repairs in 14 months
cpepper5702 is offline
post #3 of 4 Old 03-14-2014, 07:50 PM
ZMANN's Avatar
Quoted: 1477 Post(s)
fuse it for sure if you run a dedicated
but check your trailer plug if you want one that is on with the ignition there should be a wire available right there it's also high amp I run my airlift compressor on mine and a small winch to load a motorcycle
We Miss you Ronnie
ZMANN is offline
post #4 of 4 Old 03-15-2014, 08:50 PM
Military Member
That's not a bad idea at all. I agree 100% to fuse it. It's honestly up to you as to how you want to run it or where to splice for the juice. Either way, if you get in a snag, we're all here to help! I'll be waiting to hear what you end up doing!
- Colton
New Purchase:
--- SOLD ---
