Factory Sub? - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 7 Old 02-25-2014, 07:10 AM Thread Starter
jcook933@gmail.com's Avatar
Factory Sub?
Just out of curiosity, how hard is it to retrofit a factory sub when the truck didn't come with one. Does it need an amp? And where is a factory sub located? Thanks for the help.
Josh
BEASTPSD
jcook933@gmail.com is offline
post #2 of 7 Old 03-01-2014, 01:07 PM
blackcloud2k's Avatar
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
The factory sub has an amp on it. Its not hard to bolt in the factory sub, but you would need to run your own wires or buy the harness to make it all work. Its probably just easier to go aftermarket. I gave my factory sub away to a guy that was going to do the same thing, and he ended up just going aftermarket.
2015 F350 Ruby Red Platinum, SRW CCLB, Color matched Ranchhands, rigids.
SOLD:
blackcloud2k is offline
post #3 of 7 Old 03-01-2014, 01:10 PM Thread Starter
Gotcha thanks for the input. I'll probably go after market and make my own custom box. I Know that it's tight behind the rear seat and was exploring other options. Thanks again
BEASTPSD
post #4 of 7 Old 03-01-2014, 01:13 PM
It is tight, but a shallow mount 10" fits no problem in a custom box. That's what I have in my truck now.
SOLD:
post #5 of 7 Old 03-01-2014, 01:15 PM Thread Starter
Ok are you running two subs or one and where did you mount the amp?
BEASTPSD
post #6 of 7 Old 03-01-2014, 01:22 PM
I am running a single 10. The amp is mounted to the back panel of the cab. it was placed on a raised area with short self tappers to prevent poking holes all the way through the cab.
SOLD:
post #7 of 7 Old 03-01-2014, 01:31 PM Thread Starter
Ok thanks for all the info!!
BEASTPSD
