Speaker upgrades - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 7 Old 02-23-2014, 05:28 PM Thread Starter
TwinTurbo6.4's Avatar
Quoted: 82 Post(s)
Speaker upgrades
I am looking for opinions on what to go with for a speaker brand/type to upgrade from the stock ones. I don't necessarily need anything with bass because I just installed a subwoofer (which sounds awesome). I just want something that is more crisp. What does everyone recommend?
'08 F250
H&S Mini Maxx w/ Cale Thompson tunes, FloPro 5"/EGR Delete/Cold Side Pipe, Pillar Gauges and CTS2,
Gear Alloy Big Blocks 20x12 -44, RetroFit Headlights - Morimoto Mini H1's
TwinTurbo6.4 is offline
post #2 of 7 Old 02-24-2014, 11:07 AM
powercho's Avatar
I installed these in place of my front 5x7 speakers. Sounds super clear, but you have to pay for it.
JL Audio C5-525 Evolution™ C5 Series 5-1/4" component speaker system at Crutchfield.com
powercho is offline
post #3 of 7 Old 02-24-2014, 12:37 PM
jluv's Avatar
Quoted: 35 Post(s)
The C5s are good, but I'd go with a 6.5“. The ZRs are very nice, too. Even the C3s are good and cost less.
You talk about not needing bass because of your sub, but keep in mind that a subwoofer is typically for frequencies of 30-80hz. There are exceptions, but that's a common range. In most vehicles, the largest "hole" or weak spot is your midbass. Basically anything from 50-250hz (again, this range can vary, but this is the general range where most systems can't keep up). For good, quality sound, you want the best possible reproduction across the entire spectrum, and therefore, midbass is arguably the most important part to address properly.
You shouldn't have any problem getting plenty of highs from a decent set of amplified tweeters. You mention "crisp", but in reality, smoothness (and power handling) is typically what sets expensive tweeters apart from cheaper ones.
My point is that it's not hard to get lots of treble to keep up with your subs, but where you'll really notice a significant increase in sound quality is when you properly address your midbass. And to do this, you want a good set of mids (6.5 will perform better than 5.25 of same model), and you want to give them plenty of good, clean power. And deaden the crap out of your doors. Depending on the speaker, you may also look into sealing your doors. All of this takes work, but it pays off.
Anyway, just know that the "bass" from door speakers is totally different than the bass from your sub(s), and it's just as important, if not even more so.
jluv is online now
post #4 of 7 Old 02-24-2014, 03:14 PM Thread Starter
Quoted: 82 Post(s)
Thanks for the input. I understand what your saying. I just need something/anything better than the stock ones. They tend to get distorted. My dad had Bose in his hummer as well as my mom did in her Tahoe. They both sounded really good. Just been shopping around. I'm in no rush. I'm not in a hurry to go deaf.
'08 F250
post #5 of 7 Old 02-24-2014, 05:56 PM
jluv's Avatar
Quoted: 35 Post(s)
Ya, just about anything will be better than stock.
What you say is true. My hearing is really bad for my age (36), and it's 100% due to loud music.
Check out JL C3 or even C2. They are good for the price. There is cheaper stuff out there, and better stuff, but not likely cheaper AND better. No company has put more R&D into their flagship lines, and you gotta figure at least some of that rubs off into their lower product lines.
jluv is online now
post #6 of 7 Old 02-24-2014, 11:11 PM
tony97gt's Avatar
I have the c3's in my front doors and they sound amazing. I have a JL 4 channel 400w amp, that is bridged to two channels (200w per speaker) and those bad boys are crystal clear. You can turn them up so loud it's actually painful and it's still clear. Remember, you can add speakers and they will sound good, but if you want crisp clear mids/highs you're gonna need a good amp and need to tune it properly. I onyl go with JL audio for my truck and my boat. And all my stuff sounds amazing. I have the 13.5" stealthbox for my bass in my truck. Looks great and sounds great. Can't even tell it's there cause it's under the seat.
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #7 of 7 Old 02-25-2014, 07:05 AM
jcook933@gmail.com's Avatar
^^^ agree with what everyone is saying. JL has always been and always will be one of the greats. I, however, decided to go with Polk Db7s which are 5x7 full range speakers. I replaced all four because hoping for some extra sound with out adding a sub. Realize now that the rear seats tend to block too much of the sound to make them as effective as the fronts. I wired them to an alpine 4 channel amp and am very pleased with the sound. This is a much cheaper OPTION as I had less the 300 for everything. You could save a few bucks and just replace the front door speakers. This is still running through the factory head unit as well. I can only turn it up to about half on the radio before it gets too loud for me. Just my two cents. Either way as everyone said, anything other than factory will be a huge upgrade haha. Good luck in choosing!
BEASTPSD
jcook933@gmail.com is offline
