My Projector Retrofit Project - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 14 Old 02-15-2014, 12:41 PM Thread Starter
ToughSuperDuty's Avatar
In search of the perfect headlight system, i was unable to find anything pre-made that i really liked (most importantly was a quality built item), so i decided to build my own!
I have not bought any of these parts yet, i want to get the opinions of people who have done the retrofit, so i am open to any suggestions. Also, being brand new to this, I'm just going on what I've read in previous build threads so any tips or links will be greatly appreciated!
Here is my tentative list of parts i have yet to order.
New Chrome housings for 08-10 SD
08 10 Ford F250 F350 F450 F550 Superduty Chrome Head Lights Corner Lamps w Amber | eBay
Morimoto Mini Kit for TRS
Bi-xenon Morimoto Mini Stage III Kit (H1) - Complete Retrofit Kits from The Retrofit Source Inc
(not sure on shrouds yet, i plan just to run a basic bright white halo)
6" Morimoto XB LED lighting strip
Morimoto XB LED Strips - Accessories from The Retrofit Source Inc
Switchback LED turn signal lights with load equalizer
3157 Switchback Bulbs and Load Equalizers
The plan is to crack open the new chrome housing lights, paint to match orange reflector Vermillion Red (most of the reflector). Install projectors, install the LED strip on the bottom portion of the painted reflector, aim projectors etc, then seal and wire everything up.
Please let me know what i am missing (parts or process)
Thanks everyone.
ToughSuperDuty is offline
post #2 of 14 Old 02-15-2014, 09:06 PM
rickeoni's Avatar
Same setup I used, get the depot headlights as they use normal butyl sealant and not permaseal and are much easier to bake apart. You do not need load equalizers with LED T/S bulbs, just go to a Ford dealer and have them program out T/S monitoring, this is how they program emergency vehicles.
2008 F450 KR 4x4
1998 F150 XLT 4x4
2001 BMW M5
rickeoni is offline
post #3 of 14 Old 02-16-2014, 07:20 AM Thread Starter
Thanks for the reply, are all the eBay headlights manafactured by depot? Im not sure how to tell them apart.
post #4 of 14 Old 02-16-2014, 09:38 AM
MartyG's Avatar
I took my truck to the dealer to get it programed for Leds. It's only for the rear, not the front. Still need resistors on the front. 6 ohm. I learned the had way by donating $108.00 to the dealers.
2010 6.4L F350 Crewcab Lariat Long Bed.
MartyG is offline
post #5 of 14 Old 02-16-2014, 09:39 AM
MartyG's Avatar
Also look at the new mini d2s 3.0.
MartyG is offline
post #6 of 14 Old 02-16-2014, 09:41 AM
MartyG's Avatar
Couple pics of mine. My Projector Retrofit Project-1392572412067.jpgMy Projector Retrofit Project-1392572432371.jpgMy Projector Retrofit Project-1392572447638.jpg
MartyG is offline
post #7 of 14 Old 02-16-2014, 10:18 AM Thread Starter
Thanks for the pictures! Those look great, what style halo and shroud did you use? Also, any idea on the difference between the new mini's vs what i had picked out?
post #8 of 14 Old 02-16-2014, 10:24 AM
rickeoni's Avatar
I ordered mine from a local autobody supply house, way cheaper than Ebay.
2008 F450 KR 4x4
1998 F150 XLT 4x4
2001 BMW M5
rickeoni is offline
post #9 of 14 Old 02-16-2014, 10:37 AM
MartyG's Avatar
I went with the gatlin gun shrouds and 100mm xb amber leds. With the switch backs I felt like I wanted to add the amber color. I have the D2s 2.0, probably should have went with the H1 because they have better optics but the new d2s is said the be better then the h1. I was going to exchange for the 3.0's because I didn't install mine as of when the 3.0's came out, but TRS said with it being my 1st retro fit, the 2.0's would be 110% over the halogens.
Add to your list' jb weld and if you go with the 100mm angel eyes, you need the jb weld steel stick also. New butyl tape is good also.
MartyG is offline
post #10 of 14 Old 02-25-2014, 12:18 AM
tony97gt's Avatar
Butyl and shrouds should be good for ya. Are you going to cut out the old reflector bowl and JB Weld in the projectors, or are you going with the JNC method?
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
