key power on fuse - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 6 Old 01-25-2014, 12:06 PM Thread Starter
key power on fuse
i am installing at bullydog and need a power on by key fuse.. 2009 f250 6.4L.. help please.. i have tried about 20 fuses and can't find one..
thx
jschamel is offline
post #2 of 6 Old 01-28-2014, 08:31 AM
jcook933@gmail.com's Avatar
I use the 30 amp power window fuse ( big silver one) in the interior fuse box for my amp. You could also use the wiper motor fuse in the engine compartment.
BEASTPSD
jcook933@gmail.com is offline
post #3 of 6 Old 01-28-2014, 10:20 PM
tony97gt's Avatar
stereo fuse
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #4 of 6 Old 01-29-2014, 06:07 AM
spock91's Avatar
Quoted: 6 Post(s)
Maybe this will help.
Attachment 235210
Spock
spock91 is online now
post #5 of 6 Old 01-29-2014, 07:20 AM
Quoted: 2 Post(s)
purple wire under the steering column. Mine was located in a bunch of wires right behind the parking brake release. the purple wire is used by a lot of the guys running the mini maxx.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #6 of 6 Old 01-29-2014, 07:49 AM
spock91's Avatar
Quoted: 6 Post(s)
"SOLID PURPLE WIRE
The SOLID PURPLE wire (capped from the factory)
is found under the drivers side dash. This SOLID
PURPLE wire is bundled with multiple other capped
wires near the OBD-II port.
Note : If your fuse box or wiring looks different than those pictured
or if you are not getting 12V ignition power from the pictured
source, you may need to find another 12V keyed ignition source using a test light or multimeter. If possible, find one
that stays “hot” during engine cranking."
From the H&S manual
Spock
