Dual Projector Retrofit - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 11 Old 12-11-2013, 06:46 AM Thread Starter
Airborne29th's Avatar
This may have been asked before but I could not find a thread that was specific to what I am looking for. I really like the look of the dual projector's in some of the Ebay and Recon headlight but have heard the bad things about them. Has anyone done a dual projector setup like this? Is the issue that most projectors are two large to set in the housing side by side? This is all somewhat new to me other than the threads I have read through for single projectors. Just curious if it is possible to do. I am not very fond of the single projector look in the stock housing.
08 F250 6.4 Diesel Ext Cab. Long Bed XLT
3.73 LSD
Dark Blue Pearl
6 Speed,
LineX Bedliner, Dixie Horn, Pioneer Avic F700BT headunit
H&S Mini Maxx Race Tuner, AFE Stage 2 SI intake, 5" DP Back Flo-Pro
35x12.50x17 Nitto Trail Grapplers on stock suspension
Deezee Bedrail caps
Currently looking to trade my chrome bumpers and grill for FX4..
Airborne29th is offline
post #2 of 11 Old 12-11-2013, 08:35 AM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 21 Post(s)
Feedback Score: 12 reviews
From what I've seen on the recon lights they're not actually dual projectors, there is one projector then there is another headlight reflector for the hi beams. Click the link in my signature to see a true HID projector retrofit project that I have done myself, a few other members have done the same too. RECON HEADLIGHTS ARE JUNK THE LIGHT OUTPUT AT NIGHT IS HORRIBLE AND YOU'LL BE HIGHLY DISAPPOINTED. Sorry for the caps but I'm driving and Siri did it
Sent from AutoGuide.com App
2017 f250 platinum
Deleted at 8k miles.. trying to be patient waiting for custom tunes...
mts678 is offline
post #3 of 11 Old 12-11-2013, 08:36 AM
mts678's Avatar
Quoted: 21 Post(s)
You'll also get some real good information on any HID retrofitting on WW.Hidplanet.com
2017 f250 platinum
mts678 is offline
post #4 of 11 Old 12-12-2013, 04:50 AM Thread Starter
I realize the Recon's are junk and have looked through numerous Retrofit guides to include yours already. However like I said above, I am not a big fan of how the single projector looks in the housing.. To me it draws the eyes away from the rest of the truck and gives the front the look of a surprised face with open eyes. I have only come across one set that someone did that looks halfway decent. I just like the look of the Recon's, hence why I wanted to retrofit them and not use them how they currently come..
3.73 LSD
Dark Blue Pearl
6 Speed,
Deezee Bedrail caps
post #5 of 11 Old 12-12-2013, 05:48 AM
mts678's Avatar
Quoted: 21 Post(s)
You can retrofit the Recons, they're not dual projector tho. There's only 1 projector per headlight, but you can probably retrofit another projector in the halogens high beams place
Lol what you described about the look of the single projector is how I feel about Recons, but that's why beauty is in the eye of the beholder as they say
2017 f250 platinum
mts678 is offline
post #6 of 11 Old 12-12-2013, 04:42 PM
Quoted: 28 Post(s)
Does anybody have a picture of the Recon headlight output on a wall? I have searched and asked before with no answer... I'm just asking again if anybody has any information
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #7 of 11 Old 12-12-2013, 05:42 PM
The light output from a Recon projector is a full circle, no cutoff at all. If you put a hid bulb in them you get two rings of light with really dark areas in the middle, just like a Maglight flashlight that has been twisted completely out of focus. Even if you could adjust the bulb inside the housing to focus them, they have zero cutoff and would be two complete circles of light.
To retrofit a real HID projector into a Recon headlight you need:
1) A Morimoto Retro-Quik System that includes a recon/spyder headlight adapter plate to mount the projector in the recon housing ($300 with H1 bulb and ballast or $150 if you already have those)
https://www.theretrofitsource.com/pr...roducts_id=254
2) Then a Bi-xenon MotoControl 9008/H13 harness so your lights don't go out every time you activate the high beam solenoids ($35 for this)
https://www.theretrofitsource.com/pr...ducts_id=14029
3) And finally some OCI Butyl Rubber Glue to reseal the headlight ($15 for this)
https://www.theretrofitsource.com/pr...roducts_id=792
To accomplish the retrofit you need to take the headlight apart and dremmel the back of the headlight housing because the Morimoto projectors are slightly larger than the crappy recon projectors. Then you need to reseal the back of the housing with something like JB weld epoxy and put the headlight back together.
Spyder headlights (which are recon copies sold on ebay) actually have a better projector than the Recons, better CCFL halo rings, don't use a permanent glue like the Recons so they are easier to open, and they're cheaper. The Retro-Quik was made for them so you might not have to dremmel the housing of the Spyder headlights, but I'm not sure about that. If you attempt this retrofit and don't already have Recon headlights, I would try the Spyder headlights out first.
I'm actually in the middle of this project right now. I already had crappy Recon headlights so I decided to hack them up and see if I could make something better. I got too busy to work on them for a week, but the first one is almost done and I can give you some pics when I'm finished.
-Nate
2008 F350 6.4L SCSB
Veteran and Lifetime DAV member
U.S. Navy Submarines 1997-2007
U.S. Army Pilot 2008-2010
Mr Hahn is offline
post #8 of 11 Old 12-13-2013, 03:36 AM
cjglenn is offline
post #9 of 11 Old 12-31-2013, 10:00 AM Thread Starter
Mr Hahn, Thank you for your reply! Can't wait to see your finished project!
3.73 LSD
Dark Blue Pearl
6 Speed,
Deezee Bedrail caps
post #10 of 11 Old 01-01-2014, 12:25 PM
oregoncalfroper's Avatar
Quoted: 15 Post(s)
Send a message via AIM to oregoncalfroper
Yes Mr Hahn, waiting to see those pics.
oregoncalfroper is offline
