Navi w/o Sirius button - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 11 Old 09-26-2013, 10:46 AM Thread Starter
I recently purchase a 2008 F-350 FX4 Super Duty Diesel, it has the touch screen in dash navigation w/ the audiophile system, it's a job #3 as well because it was built in 2008, not 2007. The problem is there is no 'SR' tab for the satellite radio. Does this mean it's not satellite ready? What are my options? I would really like to have the satellite radio hooked up to the stock. Do they sell a stock module for it? Thanks in advance!!!
J
Vico103 is offline
post #2 of 11 Old 09-30-2013, 08:10 AM Thread Starter
I guess no one can help on this one...
J
2008 6.4L F-350 FX4 Super Duty CCSB
2.5" Ready-Lift Leveling Kit, 4" Rear Blocks
35" Nitto Trail Grapplers
18" XD Spy 797 Black Machined Rims
Vico103 is offline
post #3 of 11 Old 10-03-2013, 10:34 AM
Not sure if I'm understanding this right. Is there a black antenna on the drivers side roof near the windshield? If so that the Sirius antenna. Now hopefully they didn't take out the Sirius box and left everything in the truck. You may just heed to buy a factory head unit or one aftermarket that has the sirus hookup.
futbal2332 is offline
post #4 of 11 Old 10-04-2013, 07:37 PM
pjzr1 is offline
post #5 of 11 Old 10-08-2013, 08:27 PM
I have the same problem, I just bought an 08 f350 lariat with the same touch screen nav unit, my owners manual says there's 2 different options with radios, SR box in top right has satellite radio and if it has a line box that means it doesn't have satellite radio. i'm just starting to research this myself as I would love to have Sirius also - I hope this helps
Bull183 is offline
post #6 of 11 Old 10-09-2013, 07:02 AM Thread Starter
There is no antenna on the roof. I traded in a 06 Dodge 1500 for my new truck. My Dodge had the antenna in the middle rear part on top of the cap, this truck does not have the satellite antenna on top of the cab. My questions is do they sell a module to connect to the back of the stock unit w/ antenna? Or am I forced to get an aftermarket unit or a Sirius Radio?
J
Vico103 is offline
post #7 of 11 Old 10-09-2013, 07:06 AM Thread Starter
I'm surprised that all the radios are not Sirius ready, very surprising. I've been doing research and it looks like there are (3) options.
1. Buy a OEM unit equipped with Sirius Radio
2. Buy an aftermarket unit that is Sirius Ready
3. Buy one of those Sirius Radios, but then it needs to be mounted somewhere. Which could end up looking ****ty.
Option 3 is the cheapest of the 3, please let me know your thoughts and what you find out. THANKS!!!
J
Vico103 is offline
post #8 of 11 Old 10-11-2013, 06:18 AM
http://www.amazon.com/COMPLETE-Sirius-Satellite-Package-Audio/dp/B004F93OK0/ref=sr_1_2?ie=UTF8&qid=1381497312&sr=8-2&keywords=isimple+f350+sirius
I put this in my non navi radio but i did not have a sirius button on mine either. Shoot isimple an email and see what they say. For mine it works just like stock satellite but instead i use the aux button to turn it on. Not sure if itd work with nav but its worth it to send them an email and see
lazlow is offline
post #9 of 11 Old 10-15-2013, 10:58 AM
Ok, couple things here, first the Sirius module is separate from the radio, second is the lack of the antenna on the roof and finally would be the need to have the stock radio reprogrammed to work with the Sirius. I believe all of the trucks have the wiring for the module so you would have to buy one off of eBay or a salvage yard, the good news is all you have to do with this is plug it in and mount it. Next you can buy the factory style roof mounted antenna from any dealer (you will however need to loosen the headliner and drill through the roof to install it and run it to the Sirius module. Finally the radio will need to be reprogrammed to add the Sirius capability. Depending on where you are this can cost anywhere from $75 to $150 dollars. Or the easiest is to buy the external Sirius and plug it into the AUX jack.
jimb726 is offline
post #10 of 11 Old 10-16-2013, 06:52 AM Thread Starter
I'm thinking that the external radio may be the easiest and cheapest route. Any ideas on where to mount/hide it??? Just don't want it to look cheesy.
J
Vico103 is offline
