factory navi HU - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 8 Old 09-14-2013, 08:55 AM Thread Starter
08f3fiddy's Avatar
factory navi HU
I have the none navi HU and I have factory navi from another truck that was totaled. does anybody know if I can swap the navi radio with the non navi unit and everything will work.? will sirus still play and will the navi work or will I need to get more parts for it to work?
08f3fiddy is offline
post #2 of 8 Old 09-14-2013, 12:14 PM
blueoval95's Avatar
It should work fine. I pulled a Nav. Unit out of a Lincoln and had it reflashed at the dealer.
2008 F250 CCSB KR Job 1
EGR and DPF delete
H&S Tuner on HD 300 HOT
AFE air filter stock box with no lid
blueoval95 is offline
post #3 of 8 Old 09-18-2013, 08:19 PM
A8050266's Avatar
Send a message via AIM to A8050266 Send a message via MSN to A8050266 Send a message via Yahoo to A8050266
You will need the Navi antenna and the sirus module (as both these items are separate) then it will work. Also depending on your trucks configuration.
Steering wheel controls etc.. you might need some programing.
-=Sam
813.390.0040 / Sales, engineering, and floor sweeping. (mostly the sweeping)
2015 F350 CC FX4/Lariot SWD Platinum white
A8050266 is offline
post #4 of 8 Old 09-18-2013, 09:24 PM
JOAO's Avatar
What year truck?
Bobby William/Rick Estes took care of me at
SUNRISE FORD
08-10 20" Lariat wheels
JOAO is offline
post #5 of 8 Old 10-30-2013, 09:40 AM Thread Starter
08f3fiddy's Avatar
It's on 08 so it does not have sync. I do have Sirius and steering wheel controls as wel as subwoofer. I'm being told that an 08 model navi will be plug and play is that correct.
post #6 of 8 Old 10-30-2013, 09:03 PM
It will work but you will need a few pieces. If your new navi unit is from an 08 superduty you will need to get a new dual band roof antenna and sirius module. And I believe you will also need a 2 way splitter wire for the navi and sirius plugs. If your new unit is from an 09 and has sync on it then that's a whole new ball game. Either way it's all possible.
futbal2332 is offline
post #7 of 8 Old 10-31-2013, 03:15 AM Thread Starter
08f3fiddy's Avatar
The unit it from an 08. Why would I need a new antenna and Sirius box. The plugs on the back of the radio are the same.
post #8 of 8 Old 10-31-2013, 08:24 AM
Sorry I wasn't sure if yours was out of an 08, but since it is you still need the gps antenna and bracket that mounts inside the dash. And all the sirius stuff stays the same.
