headlight problem - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 7 Old 09-05-2013, 12:53 PM Thread Starter
headlight problem
2008 f-350. when i put my headlights on either manually, auto,unlock, etc. they stay on for about 1 sec and go off and stay off. my fog lights work just fine and high beams work also. i have a plow wirining harness on my truck but it is not even a yr old yet. could it be the headlight sensor? or something else. and if sensor how hard is it to change?
thanks for any help
mtfd49 is offline
post #2 of 7 Old 09-20-2013, 03:40 AM
Interesting question. I have same truck and same exact problem. Only diff. Is my truck had a plow harness and now does not. Lights worked fine day before. I will be calling my mech. Today to see what he knows and truck will be going to dealer for warranty repair on Tues. I will post what I find out.
Padec21 is offline
post #3 of 7 Old 09-23-2013, 06:25 PM Thread Starter
did you have any luck finding an issue? it is not related to my plow wiring harness. took out the plow harness and now my passenger light works...still no driver side. everything else is still working just fine
mtfd49 is offline
post #4 of 7 Old 09-24-2013, 04:50 PM
Mine is fixed. It was a loose connection under the hood where the plow harness tapped I to the lights. It's under warranty so the dealer fixed it.
Padec21 is offline
post #5 of 7 Old 09-24-2013, 05:19 PM Thread Starter
well thanks for the info. i have a different problem. not sure what it is yet. but when i figure it out ill post
mtfd49 is offline
post #6 of 7 Old 09-25-2013, 06:31 PM Thread Starter
i am being told it could be my smart junction box...does this seem like a possibility if anyone knows? again all lights work except my driver low beam
mtfd49 is offline
post #7 of 7 Old 10-06-2013, 03:11 PM Thread Starter
it was my smart junction box. water got into my healight adaptors for my plow caused corrosion and ended up shorting the fuze box.
mtfd49 is offline
