Factory Reverse camera to aftermarket HU - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 24 Old 09-02-2013, 01:00 PM Thread Starter
Just had a aftermarket HU installed (kenwood DNX570hd) it has the RCA camera plug on the back but the Ford camera is a set of wires.
Besides the tailgate location can someone tell me where I can tap into the camera wires to convert them to RCA? Closer to the HU the better.
Thanks
10' F350 CC SRW LWB 6.4, Green 4x4....stock for now.
Doozer is offline
post #2 of 24 Old 09-03-2013, 06:28 AM
hollywood19's Avatar
Quoted: 2 Post(s)
Subscribed... wondering the same thing.
'12 F250 Lariat CCSB - Spartan tuned 6.7 w/ No Limit Intake - 4.5" Carli Pintop, 37" Toyo MT's on 20x10 Fuels....and more!!
'03 F350 XLT CCLB FX4 V10 (Sold) - 8" Superlift Select Lift, Bilstein 7100s, 40" MTRs on Welds, 4.88's...blah, blah, blah....but had to sell it
hollywood19 is offline
post #3 of 24 Old 09-03-2013, 07:09 AM Thread Starter
I've been told that there should be a 8-10 pin plug behind the HU that only has two wires. Those wires are video+ and - Soder those onto a RCA cord and I'm good to go.
Doozer is offline
post #4 of 24 Old 09-03-2013, 07:53 AM
Is your stock backup camera viewed in the rearview mirror? If so then it wont work when you try to run it to your new head unit. The resolution for the stock camera output isn't enough to work on an aftermarket HU screen and you end up with lines running through the image and it looks horrible. I know because I just had a Kenwood DDX790 installed last week and they tried to make it work how you're talking about and it looked horrible.
I ended up buying a cheap Pyle backup camera (license plate mount) for like $30 through Amazon and it works perfect. I still have the oem in the mirror and the new one coming through the HU.
jgos929 is offline
post #5 of 24 Old 09-03-2013, 08:03 AM Thread Starter
No mine went to the Navi Head Unit so maybe it will work better...maybe
I actually have been thinking about getting one of those license plate cams for the front for those tight parking situations.
Doozer is offline
post #6 of 24 Old 09-03-2013, 08:16 AM
Yeah then you should be fine if they can tap into it.
jgos929 is offline
post #7 of 24 Old 09-03-2013, 02:35 PM Thread Starter
In my surfing for info today i ran across this help forum for idata's maestro Rr. Basically saying the problem with the mirror camera having lines might actually be the RCA cable. Using a stranded will cause noise over a coaxle RCA that is shielded. Take a look. Just for anyone else working this issue. If you look up the difference between the two cables you'll get a better idea of why the stranded causes noise.
The Ultimate Online Support • View topic - Factory Microphone Retention & Backup Camera
Doozer is offline
post #8 of 24 Old 09-04-2013, 07:02 AM
Quoted: 2 Post(s)
Great info from both!
Doozer...
That makes a lot of sense, as it does sound like it could be interference the way jgos929 describes the resulting display. Please let me know how yours works out.
jgos929...
Not sure if you know or not, but did the shop have to route the camera feed down from the headliner, or was the feed already present in the connector Doozer was referring to?
post #9 of 24 Old 09-04-2013, 04:44 PM Thread Starter
Doozer...
Finished today. Purchased a coax RCA with exposed wire end from Radio Shack $6.97. Attached to the two vid wires on the OEM harness and plugged it in to HU. I then had to connect the reverse signal wire from the aftermarket HU to a reverse signal wire in the truck. Found one under the dash by steering wheel. Works very well.
Doozer is offline
post #10 of 24 Old 09-04-2013, 08:34 PM
Quoted: 2 Post(s)
Awesome, I'm glad to hear it works.
I appreciate the update. I'm planning to buy my next truck sometime early next year (after my finances recover from a recent cross country move and new house). In the meantime, I'm trying to learn as much as I can about the newer trucks and the Powerstokes. Threads like this certainly help.
