Upfitter switch install questions - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
 2Likes
  • 1 Post By tony97gt
  • 1 Post By DieselPowerFan
post #1 of 6 Old 08-09-2013, 10:42 PM Thread Starter
live for the now
ZombieSoldier's Avatar
ok i have 2 questions about installing the upfitter switches
- I currently have the electric tow in my truck and want to get the upfitter switches. do i have to order anything specific to keep the electric tow brakes and have the switches, ie; specific harness or even might be a different switch setup, idk?
- once i install the switches, i want to wire my LED lightbar into the switches, is their a pre-existing harness in there i tap into, or?
2008 F250 6.4 - a little of this, a dash of that and soon you have made a truck the way Ford should have made it!
ZombieSoldier is offline
post #2 of 6 Old 08-26-2013, 01:16 PM
XPLOSIV's Avatar
Just installed it on my truck. It replaces the change holder. Comes with 4 capped wires that get located under the drivers side dash.
08 F450 CCLB 4.30's
Spartan, Pure Performance Custom 3", Toyo M608Z, MBRP, FloPro, Banks, Volant, Mishimoto, Dieselsite, LineX, Reese 30k
XPLOSIV is offline
post #3 of 6 Old 08-26-2013, 09:11 PM
tony97gt's Avatar
The upfitter switch bundle comes with a harness that plugs into a plug underneath the dash that is prewired for upfitter switches. Once you do that, there are four wires that go from the cabin, thru the firewall, and into the engine bay. Those are the ones you use to draw power from the upfitter switches. They are color coded based on the output of each switch because each one has different outputs. The instructions for the upfitters should explain this.
pacislander007 likes this.
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #4 of 6 Old 08-27-2013, 10:16 PM
DieselPowerFan's Avatar
Make sure when you're buying the parts that the relay and relay mount come with the switches. I had to double make sure when ordering from the dealership. Basically you'll get the switches with the wiring harness that plugs into a connector that is under the dash and to the right of the steering column. Mine was tucked WAY up in behind my dash. and then there's a metal bracket that mounts behind the dash vent on the drivers side of the gauge cluster, this is where you mount the relay to. The relay mount attaches to two metal tabs (see pics) don't mind the zip tie in the pic, I was just test fitting things. I didn't have to wire anything through the fire wall for the install. The only wires through the fire wall was the wire into the cab from the lights I installed to one of the four colour coded wires in the upfitter harness.
If you search on the forum there's a few other posts about this topic, I just did a quick search but can't find it off hand. I'll include some pics below of my install, hope they help! Oh and if you do a google search for Ford upfitter install, you'll find tech support sheets from ford that will help you with what amperage comes from what colour wire and what switch can handle that many amps etc.
ID:	160609   Click image for larger version
ID:	160617   Click image for larger version
ID:	160633   Click image for larger version
ID:	160641   Click image for larger version
DieselPowerFan is offline
post #5 of 6 Old 08-27-2013, 10:20 PM
More pics, Hope these might help.
ID:	160657   Click image for larger version
ID:	160665   Click image for larger version
ID:	160673   Click image for larger version
post #6 of 6 Old 08-27-2013, 10:42 PM
