Mirror turn signal not working - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 10 Old 08-01-2013, 04:12 PM Thread Starter
preston77's Avatar
Neither turn signal on the mirrors work. Bulb is fine, tried the aftermarket led's, switched the polarity on the led's and nothing. Can't find anything in the owners manual on a fuse for them either. Thanks in advance, Preston
preston77 is offline
post #2 of 10 Old 08-10-2013, 04:48 AM Thread Starter
preston77's Avatar
Bump......
post #3 of 10 Old 08-17-2013, 05:33 PM
ynpmoose's Avatar
Quoted: 7 Post(s)
I looked at the 2008 wiring diagram and fuse layout. Check fuse #21 - 15Amp (Fog lamp relay feed, Cornering lamps). It looks like a single fuse does both mirrors.
Moose
SOLD - 2003 Excursion 6.0L 4x4
ynpmoose is offline
post #4 of 10 Old 08-20-2013, 05:20 PM Thread Starter
preston77's Avatar
Negative on #21 ghost rider, but thanks.
post #5 of 10 Old 01-16-2014, 12:30 PM
bullfighter1777's Avatar
did you figure out the problem? my 2010 kr has same problem.
I check the fuses as well as chanding out bulbs. the mirror marker lights work fine but the turn signal lights on both sides are not working at all. any help?
BULLFIGHTER1777
bullfighter1777 is offline
post #6 of 10 Old 01-16-2014, 12:59 PM
jse51599's Avatar
I have a similar problem with my mirrors... on mine the parking lights don't work, but the signals do. My problem is the wiring in the loom between the door and the cab. Apparently, one of them pinched and I can get them to come on by moving the loom around. Obviously not the same truck or exact problem, but maybe it's a place to look if you haven't already.....
6637, Diamond Eye Turbo Back, Riffraff Billet Intake Plenums and Intercooler Boots, WW2, Deleted EBPV
305 70 16 Toyo A/T IIs
Jim
jse51599 is offline
post #7 of 10 Old 01-17-2014, 05:12 AM Thread Starter
preston77's Avatar
I haven't figured it out still, I kinda just gave up lol.
post #8 of 10 Old 01-17-2014, 05:17 AM
Well at least I'm not the only one with this problem. I've seen several trucks around town with the same problem too.
06-f250 KR
FawlGuy is offline
post #9 of 10 Old 01-17-2014, 01:16 PM
ok< ill check the wiring around door jam tonight. my truck is still under warranty, should i take in for them to mess with it?
BULLFIGHTER1777
post #10 of 10 Old 01-17-2014, 03:09 PM
jse51599's Avatar
As long as you double check fuses and bulbs. I took a car in for service one time for power windows not working and came out with an $80 charge to replace a blown fuse....
Jim
jse51599 is offline
