Amp location in 2010? - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 18 Old 06-29-2013, 08:13 AM Thread Starter
Hi all, I've been scouring the Internet and can not get an answer I can depend on ...if I even get an answer. Hoping someone can help.
I want to upgrade my system by replacing everything but the HU. I need to know where the amp is for my system so I can hook up my line processor then my new amp downstream.
I've heard it's under the dash or its under the center seat, or its built into the HU. I've checked in the dash and just don't see one. Nothing is under the center seat. So I'm trying to confirm its existence and or location. Can't find a wiring diagram either (unless I pay $50-100 for a manual).
I have the 8 speaker Premium Sound with Nav and sync.
Any help would be appreciated.
Thanks
10' F350 CC SRW LWB 6.4, Green 4x4....stock for now.
Doozer is offline
post #2 of 18 Old 06-29-2013, 10:07 PM
44magnum's Avatar
Quoted: 2 Post(s)
Do you have the factory sub behind the right rear seat? if so the sub is in that plastic box. If you don't have the sub I'm afraid I don't know.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #3 of 18 Old 06-30-2013, 05:33 AM
thedynoguy's Avatar
it's up on top of the parking brake. Next to impossible to get to without taking a bunch of stuff out first. Trust me it's there, I had to deal with it when doing my stereo a couple of years ago...
2010 F350 CC SWB FX4 loaded... Truxx leveling kit with an Icon adjustable trackbar, 20X10 XD Monsters with BFG 285X65X20 AT KO's, S&B intake, H&S Blackmaxx with DPF/Cat delete and MBRP Cool Duals, SD card full of KEM tunes that sits (unused) in the console. Audio by Focal, Audio Control, and JL Audio...
thedynoguy is offline
post #4 of 18 Old 06-30-2013, 02:30 PM Thread Starter
magnum
There is an amp there but I believe it is for the sub. I could be wrong though. I had a 2008 and the premium sound is different then the 2010. The 2008 actually sounds a LOT better.
Doozer is offline
post #5 of 18 Old 06-30-2013, 02:32 PM Thread Starter
I'll check again. It will be a pain because that is where I put my car remote start module and it was tight. Right next to the relays for the upfitter switches.
I see you have an audio control and JL. I assume you installed it down stream from the factor amp? Where did you end up installing it and the new amp?
Doozer is offline
post #6 of 18 Old 06-30-2013, 03:01 PM
44magnum's Avatar
Quoted: 2 Post(s)
Originally Posted by Doozer View Post
magnum
Oh ya, it's for the sub. Guess I'm only familiar with the 08's. Good luck.
44magnum is offline
post #7 of 18 Old 07-01-2013, 04:01 PM
thedynoguy's Avatar
Doozer, it was a royal pain in the can! Crutchfield swore there wasn't an external amp. So, I spliced in to the (what I thought were the speaker level outputs coming out of the OEM stereo. After calling crutchfield and audio control many times, I called a friend that is a Ford tech and he told me where the amp is. So, after re-splicing all of the wires I fed the audio control from the speaker wires between the OEM amp and the speakers. Then, I ran all new speaker wires from the JL 900/5 that I mounted under the passenger rear seat on an aluminum plate that I installed in place if the cargo tray. A lot of work for sure, but so worth it in the end.
post #8 of 18 Old 07-01-2013, 06:16 PM Thread Starter
Dynoguy, thanks for the info. I'm going with JL c5 comps in front and coax in the back with a sub ( don't know which yet), LCQ-1, and a JL 900/5 also. What sub did you go with and where did you install your audio control component?
Doozer is offline
post #9 of 18 Old 07-01-2013, 07:05 PM
thedynoguy's Avatar
I've got the JL stealth box under the 2/3 of the rear seat. It's ok, but it doesn't hit like the Supercrew sound box I had in my old super duty. I'm not sure I would do the stealthbox again. The DQL8 is in the center console.
post #10 of 18 Old 07-01-2013, 07:29 PM Thread Starter
I don't listen to music with big bass. mostly rock, country. If you want to sell the stealth box let me know. I think I'll put the LCQ-1 under my front center seat also. Did u buy your wire/cable from JL?
Doozer is offline
