Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Electronics Discussion
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 04-01-2008, 09:16 AM
PressureDrop PressureDrop is offline
Μολὼν λαβέ
Send a message via ICQ to PressureDrop Send a message via AIM to PressureDrop Send a message via Yahoo to PressureDrop
Access functions while +5mph ?
Has anyone figured out a bypass on the navigation functions that "gray out" when in motion +5mph? (OEM navigation head unit).
To me it would be safer to use some of the functions in DEST while in motion than it is to use some of the ones that are NOT grayed out!
Old 04-01-2008, 05:01 PM
SPL2K SPL2K is offline
One of these days when i have time, im going to have someone with an 08 navigation equipped truck drop it off with me for a day so i can come up with a bypass for it.
Old 04-02-2008, 06:07 PM
A8050266 A8050266 is offline
Send a message via AIM to A8050266 Send a message via MSN to A8050266 Send a message via Yahoo to A8050266
count me in.... boy that would be a great feature
Old 04-04-2008, 05:55 PM
All interested.
I spoke to a techie friend of mine. he says the new models that use the
can bus system are difficult to bypass since if you cut the can wires the radio/nav will
throw errors and complain. the older models you could disconnect the vss wire. and bypass the Eb switch. this is not the case on these newer units. Im told what's needed is a computer that can simulate the same data produced when the vehicle is not moving so this is not good news... but news all the same. Im investigating Can buss emulators / simulators. maybe this will be the solution. Ill post my findings.
Old 04-06-2008, 12:02 PM
BJacobsKR6.4 BJacobsKR6.4 is offline
Why can't this be a simple fix
Old 07-15-2008, 12:49 PM
Any new news on this topic?
Old 07-22-2008, 08:18 AM
etalian etalian is offline
Send a message via AIM to etalian
Lexus started doing the "lock out" on their new models and the problem was solved by unplugging the "sensor" from the back of the nav. Do you think that this is as simple of a fix?
Old 08-07-2008, 08:10 PM
I wish it were this easy. Our NAV units don't have a sensor to unplug
great thought though
Old 08-08-2008, 06:58 AM
Yea, it was easy. The hardest part was pulling off the A/C vents. All you had to do was unplug one wire and then splice 1 or 2 others. But they changed it on the '08s so there is no hack for it.
Old 09-21-2008, 10:00 AM
zeddy zeddy is offline
Dont flame as I am just trying to come up with a solution also BUT
1. if they changed it for 08 why do they use the same radio(I just had a nav deck from an 07 programmed to work in my 08.
2. The 08's use the can bus system but is the speed sensor on this system or is it still plug in.
3. Bump
