Battery Drain, F250, 6.4L, 2008, TD, XL - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 15 Old 06-16-2013, 06:52 AM Thread Starter
Battery Drain of about 1.5 Amp. Internal fuse #5 pulled solves Drain (30ma).
Anyone have a schematic for this truck?
What device/s are connected to this fuse?
Any history on this fault?
Thanks.
vjsimone is offline
post #2 of 15 Old 06-18-2013, 05:32 PM
I have the book for the truck. Give me a day or two and I'll see if I can get you an answer.
futbal2332 is offline
post #3 of 15 Old 06-18-2013, 05:52 PM
The internal fuse box on the pass side kick panel #5 is a 10amp keyed illumination, Brake shift interlock
If this is the fuse you are talking about it goes to the keyless entry. It's also goes to the brake shift interlock which is a 3 pin connector on top of the steering column. Pin 1 goes to ground. Pin 2 transmission park detect. Pin 3 powertrain brake shift interlock.
The keypad connector is in the door and funs through the main door harness
If you're referring to the engine bay fuse #5 it goes the the trailer brake control module
Hope this helps. If not shoot me a PM with your number and I'll help ya out.
post #4 of 15 Old 06-18-2013, 07:07 PM Thread Starter
Thanks, I'm going to take a look at the Brake-Interlock in a few days.
vjsimone is offline
post #5 of 15 Old 06-22-2013, 11:19 AM
StrokedInMT's Avatar
what made you decide to pull internal fuse #5 ?? i am also having a recent issue with battery drain... how do i trouble shoot this?
i thought it was just draining because of work i was doing on it (doors/hood open/closed etc. over a period of time) but then i drove for hours and thought it would be charged up. less than a week later, drained..!!
Cody
2008 F350 BLACK CC/SB
MODS:
Lots of LineX, custom bumper, 12,000#warn, tool box, XD Revolver wheels, tint, Weather Tech floor mats and vent visors, overhead gun rack, underseat pistol mount, custom blacked out taillights and mirror blinkers, PIAA lights (not impressed), center console
As they say:
"Once you go black, you never have to polish chrome again"
StrokedInMT is offline
post #6 of 15 Old 06-22-2013, 03:55 PM Thread Starter
I just went thru the process of elimination. I put the amp meter in line with the Negative terminal and post. then started pulling the fuses one at a time, when I pulled Internal #5, the draw went from 1.5 amps to .040 amps, and when everything went to sleep, it dropped to .020 amps, or 20ma. Next step is to pull the plug on the interlock device and test the draw again. I don't have the keyless entry feature. Interlock device is $100, non returnable.
vjsimone is offline
post #7 of 15 Old 06-22-2013, 03:58 PM Thread Starter
Alternater can cause a draw when the regulator is failing, no fuse for that.
vjsimone is offline
post #8 of 15 Old 06-22-2013, 04:34 PM Thread Starter
vjsimone is offline
post #9 of 15 Old 06-22-2013, 04:41 PM Thread Starter
vjsimone is offline
post #10 of 15 Old 06-22-2013, 04:47 PM Thread Starter
vjsimone is offline
