Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Electronics Discussion
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 03-20-2008, 07:38 AM
carter31 carter31 is offline
Speed sensor
I need to know which wire is the speed sensing wire for my aftermarket nav unit.
Old 03-20-2008, 09:45 AM
rdkl rdkl is offline
Send a message via AIM to rdkl Send a message via Yahoo to rdkl
Take a look at this thread. Has all the info you need.
I used the wire off of the wiper motor harness.
vehicle speed sensor (VSS) info needed
Oh, and
Old 03-20-2008, 11:17 AM
Thank you that should be easy enough.
Old 03-20-2008, 11:19 AM
I forgot to mention, I used one of the pass-through wires that are under the dash to get to it.
Old 03-20-2008, 11:23 AM
BigRed BigRed is offline
Broken...
If you have a radio that the volume goes up with the speed, there is a gray/black wire on the radio harness. There is also a speaker wire the same color so make sure it is not one of the speaker wires...
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
