Cooling fan - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 18 Old 06-05-2013, 07:23 PM Thread Starter
Skorchrock's Avatar
Cooling fan
Has anyone fitted electric fans to the 6.4 with out spending $600 on Flex-A-Lite?
Skorchrock is offline
post #2 of 18 Old 06-05-2013, 10:50 PM
h1gg1n5's Avatar
I'm interested in this as well. Ya can always be a little cooler...
I couldn't even find a Flex-a-lite to fit our trucks either though.
2008 F450 CCLB KING RANCH
H&S Mini Maxx w/ Gearhead Tunes | DPF & EGR Removed | Downpipe | CAC Pipe | CCV Mod | Injen CAI |Dieselsite Coolant Filter & Boots| Mishimoto Rad | BFC Headlights
h1gg1n5 is offline
post #3 of 18 Old 06-06-2013, 11:02 AM Thread Starter
Skorchrock's Avatar
They have them with some sort of relay the runs with the truck computer. One MAJOR flaw with Ford! There has to be some way to bypass that or use electric fans on another model that's equipped with the same computer controlled setup.
post #4 of 18 Old 06-06-2013, 11:21 AM Thread Starter
Skorchrock's Avatar
http://www.summitracing.com/parts/fl...view/make/ford
post #5 of 18 Old 06-07-2013, 06:15 PM
h1gg1n5's Avatar
Ouch! $669.95 is a pricy upgrade for sure. I would think that someone would have found a solution on here for something else. I'm surprised no one has chimed in yet with any thoughts.....
h1gg1n5 is offline
post #6 of 18 Old 06-07-2013, 06:47 PM
44magnum's Avatar
Quoted: 2 Post(s)
Are you talking in addition to, or in replacement of, the stock fan? Normally the electric ones just cant pull enough to replace the stock one. If you want to add on one, you could always do a universal fit one and run it up to a switch or upfitter.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #7 of 18 Old 06-07-2013, 07:30 PM
john galt's Avatar
Quoted: 1311 Post(s)
this is exactly what I was thinking of doing on my early 04 as I will tow heavy from time to time and live in the mountains and was concerned about high oil temps with the bpd towing heavy. seemed an easy fix to get a little more flow.
I was looking at these two
http://www.summitracing.com/parts/sum-890015
http://www.summitracing.com/parts/hfm-zfb16s
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #8 of 18 Old 06-10-2013, 12:16 PM Thread Starter
Skorchrock's Avatar
Looks like it would work. My problem is not only am I looking for a way to replace my stocker with electric fans but I also race the truck so it will help with HP and TQ. I just think it's ridiculous the Ford makes it to where the cooling fan and A/C run together through the computer. 2 15" fans "of good quality" with a shroud should do the job just fine. It's the over ride part I'm stuck on also.
post #9 of 18 Old 06-10-2013, 12:27 PM
john galt's Avatar
I was going to do this in addition to the stock fan. if you wanted more control you could put in a manual over ride switch on or under the dash. just my $.02
I like mead
post #10 of 18 Old 06-10-2013, 03:33 PM Thread Starter
Skorchrock's Avatar
Well honestly...I was going to add a 16" to the front of the IC. Seems like a good idea being I live in the ******* part of Texas. Right now I need a clutch for the fan. Thats where all this stated. So I was looking into alternatives to spending 6 bills on a electric set up from Flex A Lite
