Bluetooth not working - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 8 Old 05-16-2013, 08:39 PM Thread Starter
RobertS450's Avatar
Quoted: 14 Post(s)
Hi guys I just picked up a new to me 2010 F450 and the bluetooth does not work in the truck. I have the factory Sync/nav system. Everything else works just fine with the nave and sync systems it just that when you go into the system to look for the bluetooth part of it everything is blank and my Iphone 5 also does not find a bluetooth signal. Oh also the USB and aux port does not work. Any ideas on how to fix the bluetooth or should I just upgrade to a aftermarket dvd/nav system??
Robert
2010 F450 CC LB 4x4 Black.
RobertS450 is offline
post #2 of 8 Old 05-28-2013, 09:43 PM Thread Starter
RobertS450's Avatar
Quoted: 14 Post(s)
Nobody has any ideas as to how to fix the issue of the bluetooth not working??
Robert
post #3 of 8 Old 05-29-2013, 03:16 AM
thedynoguy's Avatar
the only thing you might want to try is resetting the system. There is a "reset to original settings" button somewhere in the menu. I've never tried it because mine works fine. Might be worth a shot...
2010 F350 CC SWB FX4 loaded... Truxx leveling kit with an Icon adjustable trackbar, 20X10 XD Monsters with BFG 285X65X20 AT KO's, S&B intake, H&S Blackmaxx with DPF/Cat delete and MBRP Cool Duals, SD card full of KEM tunes that sits (unused) in the console. Audio by Focal, Audio Control, and JL Audio...
thedynoguy is offline
post #4 of 8 Old 09-22-2013, 10:31 AM
Mine just quit too. Same scenario. Did you figure out how to fix it?
Sent from AutoGuide.com App
09Harley350 is offline
post #5 of 8 Old 11-09-2013, 11:43 PM
Wondering if you found a solution for this or not??
post #6 of 8 Old 11-10-2013, 12:36 PM Thread Starter
RobertS450's Avatar
Quoted: 14 Post(s)
No I never did get it fixed but I think it was the factory bluetooth that took a dump. I ended up replacing the head unit and just use its bluetooth system.
Robert
post #7 of 8 Old 11-10-2013, 03:41 PM
Good evening sir and forum....
Any interest in selling the factory nav system? PM me if so
2010 F-350 6.4 CCLB FX4
4.5 carli, deleted, spartaned
1999 F-250 v-10 CCLB LARIAT(sold)
Sufbark is offline
post #8 of 8 Old 11-11-2013, 10:20 AM
Does the factory unit have a front input so you can connect with a cord?
2005 Eddie Bauer X 6.0
2005 Limited X 6.0
2008 F350 6.4
Yes it's true, I am the most interesting man in the world.
Dos X's!
Tom Doniphon is offline
