dome light troubles - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 5 Old 04-27-2013, 07:24 PM Thread Starter
rickeoni's Avatar
dome light troubles
Just replaced my dome light bulbs and now I have issues. Dome lights do not turn on with door opening or with dimmer switch. They will turn on individually by pushing the lens switch. Fuse 9 looks good, door ajar warning works. WTF did I do wrong?
2008 F450 KR 4x4
1998 F150 XLT 4x4
2001 BMW M5
rickeoni is offline
post #2 of 5 Old 05-01-2013, 11:56 AM
Error 404: Page Not Found
Quoted: 6 Post(s)
Do you have a volt meter? I would take the covers off, and open the door. Then just test to see if you have voltage. At least you can start working backwards from there with the volt meter.
08' Lariat CC F250
MODs:
Spartan Tuner - Running 275 LL
DPF/CAT Delete
S&B Intake
This We'll Defend
SWhetsel is offline
post #3 of 5 Old 01-19-2015, 03:12 PM
DUstroker08's Avatar
I'm having the same problem any luck on figuring out what it was?
DUstroker08 is offline
post #4 of 5 Old 01-19-2015, 05:40 PM
sgschwend's Avatar
Quoted: 4 Post(s)
I have the same issue, it appears to be a chassis ground. I thought designers dropped that idea.
I find if I pull on the light fixture it will begin to work again. Don't forget I think the computer plays a part in the sequencing of the lights.
sgschwend is offline
post #5 of 5 Old 01-21-2015, 11:51 AM
Any idea how to fix it? I replaced the led's with halogens and still having the same problem..
H&S, Flo-Pro,Memphis, Westin, Recon, Hatchie Bottom
Fayette County Technical Rescue Team
